Briggs + Stratton Natural gas/LP 10k/9K "Under Voltage error".
I have a Briggs + Stratton Natural gas/LP 10k/9K standbye generator. As the temperature gets colder it goes off after about 30 seconds on an "Under Voltage error".{The colder it is, the more starts it takes } After several starts of Under Voltage error's it seems it reaches the desired temp and runs perfectly. On warmer day above approx 60+ degrees it starts and runs perfect. The gas line is one inch black pipe approx 14 feet of pipe with 5 -90 degree bends There is no load on the generato
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
  • 182 Answers
sounds like your filter is plugged or dirt in the coil or blower wheel.
Posted on Jul 29, 2008
SOURCE: Oven doesn't reach temperature
Page 6 of the owner's manual:
Adjust the temperature calibration.
Posted on Sep 05, 2008
  • 588 Answers
SOURCE: I have a comfort zone
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Posted on Aug 02, 2009
Looking for a special B/S carburator the run on natural gas, and not regular gas.
there are natural or lpg operated engines in gen sets being sold currently on the market
try talking to a gen set repair /retailer shop to get the make of carby being used on those motors
regardless of the engine make , what is required is the engine capacity (CC) so that the correct flow rate for the engine through the carby can be sorted to get the correct carby
once the carby is identified , it may be possible to get it from e-bay or a gen set manufacture spares that makes lpg or natural gas gensets
Nov 19, 2016 | Coleman Electrical Supplies
Model o3o319 portable generator not getting gas or air has spark
your filter inside tank may be clogged take aome air and blow in the out let of gas to see if it maybe dirty. check the fuel line itself maybe weak inside and collaisping and not allowing fuel.
May 10, 2014 | Briggs & Stratton Briggs and Stratton...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Model# BWH30NLTB
Unit goes under sure heat name also.
My unit emitted unburnt gas smell the minute pilot started,
and was annoying during burner operation.
I discovered they built unit with primary pilot that had 2 ports.
They used LP and sealed off natural gas,instead turning lp/nat
knob on back activates second pilot for natural gas use.
This means natural gas goes thru LP pilot orifice and burns
slightly off during normal natural gas use(by design).
The unused natural gas orifice has 1 air mix hole and the LP orifice
has 2 air mix holes.
I carefully plugged 1 of the holes in the LP orifice and suddenly
pilot gas flame seated correctly on orifice port.Gone was the
unburnt odor of natural gas.
The typical flame in a flame appearance now was exhibited by
the small pilot,secondary pilot remained consistent with manual
Of course, to use with LP I would have to open blocked air mix
hole in addition to the other changes per manual.
Hope this helps someone with similar condition.
Dec 31, 2012 | Reddy Heating & Cooling
Briggs & Stratton 12KW Model 040229 LPG Generator. 96 Volts @ the 120 Volts outlet, When I turn the house 2 Ton AC voltage increase to 106 Volts.
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Jun 27, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
