Question about FreeMotion Xtr 90 Treadmill By Free Motion
Freemotion xtr90 only starts running if you lift the right side and lean it slightly to the left. It stops running as soon as you lower it back down.
  • Chris Vann Apr 18, 2015
    The treadmill was working fine until I moved it into my garage during the winter. I used it in the garage once, but the next time I went to use it, the treadmill only moved about foot and then quit. I looked in the owner's manual and it said not to use it in a cold place or it could damage the components. I checked several things on the treadmill and eventually decided to purchase a new motor speed controller. I replaced it and the treadmill still doesn't work. In moving it, I discovered if I lifted the treadmill up on the right side by about an inch, then the treadmill would start working, but then as soon as I lower it, the treadmill stops.
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: freemotion xtr90 treadmill will start and run, but belt stops abruptly.
please LUBE the deck belt inmediately.
2) LUbe the rollers bearing too
3) test the input voltage motor , if there are the motor need repair.
4) Test the output motor board,if there are NOT voltage the board is faulty.
God bless you
Posted on Aug 27, 2012
Kenmore top load washer,model 110 20102311,should i be able to move tub from top very easily in any direction or should there be some tension,my tub is banging of side walls in spin cycle
The tub should move easily from side to side, however, a better test is to push down sharply on the tub and let go, it should come up and stop the first time, not bounce up and down several times. If it bounces up and down the suspension rods are shot. The part number for the kit of 4 is W10780045, all 4 need to be replaced as a set. To replace them the top needs to be loosened and lifted up, the rods disconnected from the top 2 at a time and replaced (doing opposite corners makes it easier IE: front right and left rear, front left and then right rear). Disconnect the top ends of two rods, lower top, lean washer back and pull out the disconnected two rods from the bottom, reverse the process to install.
Sep 30, 2017 | Kenmore Washing Machines
I have a Freemotion XTR90 treadmill that stops / resets after 5 min of use.
see the video attached, Lube the rollers bearing too Front+back. However you must test the main motor, measure the input voltage terminal at motor, if there ARE AND THE motor NOT run the motor is faulty. 2) test the output voltage terminal control board, for input voltage motor, if there ARE NOT the board is faulty. see the diagram attached.
Nov 26, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
Freemotion xtr90 treadmill will start and run, but belt stops abruptly.
God bless you
Aug 26, 2012 | FreeMotion Xtr 90 Treadmill By Free Motion
When I push the start button, it makes a loud humming noise like its going to turn on, but it doesn't and I hold down the button for a few seconds and then the noise stops and it just goes dead.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 14, 2011 | Kenmore 67632 Electric Dryer
The Problem - When I hit Start, the dryer does not start, I just hear a clicking sound. dbvh512efww does not start
Belt routing....http://www.applianceaid.com/images/belt-config.JPG
Installing the belt
facing down.
Please RATE me
Jan 06, 2011 | GE DBVH512EFWW Dryer
Dryer will turn on when you hit the start button, however it just hums. It did this last week and then i tried it another day and it started back up and went until it stopped, now will not come back on
Installing the belt
facing down.
Please RATE me
Jan 03, 2011 | Kenmore 800 7983 Dryer
I have a 2004 range rover and i noticed while i was driving that my right front end was leaning lower than my left front side and a message came on saying that the air suspension is inactive. Help what is...
Probably the ride height sensor has failed or come unplugged, Crawl under the right side and check it is still connected, if so undo the arm connecting it to the lower suspension arm. Now get someone to start the car whilst you manually move the sensor arm up and down. If nothing happens to the ride height the sensor is gone,or the wiring is damaged or something, and will need to be replaced
Sep 26, 2010 | 2004 Land Rover Range Rover
If you have a motor mount going bad, are you suppose to be able to hear a noise of some kind?
Not usually. when a mount is bad, you can FELL the car **** when accell of a stop or changing from Drive to reverse. To check it, put on your parking brake, now hold the brake pedal with your left foot, now put the car in reverse, and press the gas slightly, the engine will move slightly, now put it in drive, the engine should shift slightly, if it moves a LOT like a few inches or moves upward, you may have a mount bad and it needs to be inspected.
May 12, 2010 | Hyundai Motor 2004 Sonata
Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Apr 06, 2010 | Icon Exercise & Fitness
Tailer is leaning to one side
you may be able to fix it with a small lift kit.if the springs are not broken
Mar 18, 2009 | Boating
FreeMotion Xtr 90 Treadmill By Free Motion Logo
77 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
