Question about Radio Communications
On motormu2080d, I finally got frequency changed. It still is not receiving or sending. What do I need to do?
    Master:
  • 517 Answers
This one is new for me, so if you posted elsewhere, bear with me. You changed the frequency, I assume to match another radio. Now you must also change the Tone, called PL, DPL,or CODE, etc. Both frequency and tone must be EXACT. Such as Frequency 2, code 1. which is default channel 1 on UHF radios. Also be certain you are not trying to match to an RMV radio, and RMV and RMU cannot talk to each other.
Posted on Apr 15, 2015
L4diversity wireless receiver adjust frequency shure and microphone sm58
Sorry, it's not possible to adjust the frequency of the L4 wireless receiver. These were single frequency, crystal controlled systems. To change the frequency would require changing a dozen components on the board and then retuning the filters on the receiver board to work with this new frequency.
Aug 07, 2014 | Shure Audio Players & Recorders
Everything works but can only send and receive within 50 yards of other radio
check swr's and the antenna installation. if all is good. have the radio checked out. ITS should be FREE!!!! to see if it has any rf power out put could have a bad rf final transistor.....
Feb 04, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Modify frequency on a T4A shure reciever
The T-4 has fixed frequencies, the only way that maybe could work is to send it to your distribution centre.
Regards,
Gerard
Mar 30, 2010 | Shure T4A DIVERSITY AC RECEIVER (CV) T4ACV...
What do hpf and lpf switchs do
Hello rwalinske, The abbreviations "hpf" and "lpf" stand for High Pass Filter and Low Pass Filter. They do exactly what their names imply. They allow frequencies above or below a specific setting, while blocking or attentunating frequencies below or above the setting. There's also a "band pass filter" which allows frequencies within a specific range below the high setting and above the low setting. Finally there's a "subsonic" filter which blocks inaudible frequencies below the threshold of hearing. The hpf is generally used in speaker component systems to send the high frequencies to the tweeters. The lpf is normally used with subwoofer systems and is set to send frequencies below the setting to the subwoofer. While most amps will amplify a wide range of frequencies, they are more efficient when the range is limited depending on their intended use. For example, a typical 2-channel amp might have a frequency response of 20-20KHz. When used to drive a set of normal speakers, you would not use either the lpf or the hpf, but simply let it send all frequencies to the speakers. But when used to drive a subwoofer, and operated in "bridged" mode, the amp can put all of it's amplifying power into frequencies than can be used by a subwoofer if the lpf switch is turned on. Hope this helps.
Jun 05, 2009 | Sony Car Audio & Video
Icom ic720a ham radio not transmitting, pliz help
upon what frequency are you trying to transmit?
Perhaps the radio is blocked from trying to TX on said frequency.
Mar 17, 2009 | ICOM Informatique Radio Communications
Working principle of super heterodying receiver
you can find it easy with google, but here is how it works...the incomeing rf signal is mixed with a signal of another frequency from the local oscillator and then passes through a non linear device (semiconductor). after passing through the nonlinear device the output will contain the original frequency,the local oscillator frequency, and frequencies equal to those added together and subtracted from each other,these signals are then passed through filters to obtain only one which will be either the rf frequency plus the local oscillator frequency or the rf frequency minus the local oscillator frequency. This new frequency is then coupled to the intermediate frequency amplifier stages where most of the amplification takes place before the audio is removed and passed to the audio stages.
Jan 13, 2009 | Computers & Internet
Crossover?
A crossover is a circuit that breaks down a whole spectrum of frequencies into groups. For example, your speaker has 3 individual speakers (drivers) in it. There is a woofer, mid and tweeter. A crossover will send the appropriate frequencies to each of the drivers. The woofer can not reproduce high frequencies so it doesn't make sense to send them there. The sam can be said for low frequencies and the tweeter. The crossover point defines the splitting point of the frequencies. Depending upon what sub-woofer you are using usually the crossover freqwuency is either 80 or 100. Most often it is 100.
Hope this helps,
Dan
Aug 20, 2008 | Onkyo TX-SR503 Receiver
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Radio Communications Logo
151 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
