Question about Sole Fitness F63 Treadmill
Main drive belt is squeaking, How do I stop the squeak?
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
Tip
Squeaking of belt noise
A use tip for all car owners. no specific model/make.
The Belt of the a/c to the solenoid pulley or the main belts can create a lot of squeaking noise.
Start the car to hear the noise now pour some water into the belt and the noise will subside off . You have the noise confirmed of a belt as sometimes it will trick you to think of water pump bearings, alternator bearings or even engine noises.
Stop the engine and check for play in the belt if so tighten the belt If not use some chalk power or candle wax to be rubbed into the belt that was making the noise - the a/c drive belt - or the main belts..
Now start and check . the nosie would be reduced or gone.
You can have the belts changed sooner or later.
on Aug 31, 2010 | Ford Fusion Cars & Trucks
2006 Nissan Sentra. Belts squeaks and stop seeking when you step on brakes.
If I understand this, your fan and other belts driving components in the engine bay stop squeaking when stepping on the brake? Your belts may need some adjustment to tighten. But it may be a vacuum hose leaking around the power brake chamber, or it is leaking, and sounds like the squeeking you describe. I would temporarily confirm the belt squeak by using a "Belt dressing spray" from your auto parts store, to see if it really is the belt or a possible vacuum leak. My belts squeak sometimes after the first start of the day in cold weather since the alternator is working very hard to recharge the battery after the start. It will be quieter when the engine is slowed down as in your braking scenario.
Mar 24, 2015 | Nissan Cars & Trucks
There is a recurring loud squeak from under the hood. What is it?
May be a worn on loose drive belt that squeaks as the engine idle speeds up as you change gear. Spray the belt with WD40 or similar . If this stops the squeak tighten or replace the belt.
Sep 28, 2014 | 2000 Toyota ECHO
Why does my 1991 subaru squeaks then cuts out for a sec.
If it's happening while driving and no brakes applied it's probably a belt causing the noise. There's a product available in most local auto shops that you can use to lubricate the belt. I think the actual name is "stop squeak" but I'm not positive.
If it's squeaking while breaking you may need new breaks or your breaks may be too tight. Another product exists for breaking squeals available in your local auto shop
Aug 27, 2014 | 1991 Subaru Legacy
I have a squeak that will not stop now, it started out in the morning time when it wad damp it would make a screech squeak noise, then stop as I started to drive it, I have just recently replaced the...
Alternator belt is loose or there is oil on the pulleys or belt making it slip instead of charge the battery. Check belt tension on your belts
Sep 29, 2013 | 2000 Mitsubishi Galant
How do you tighten AC fan belt
i have 96nissan pathfinder and belt squeaking when i start the engine and stop and start squeaking when iam driving and stop and come back it a new belt
Jun 29, 2012 | 1996 Nissan Pathfinder
The motor squeaks both on the up and down modes. model no. 248739m. ?It is two weeks old and squeaked from day one.
I just installed this opener 1 week ago and the same thing happened. I remembered there is a "Belt Cap Retainer" that covers the motor sprocket and is held on with 2 screws. I removed the cover and the squeaking stopped. There is a small dab of grease (silicone?) that the instructions did not mention. I spread the grease around the cover next to were the belt travels and put the cover back on careful not to over tighten the screws. No more squeak!
Feb 15, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
2010 electra glide ultra classic, squeaking noise from primary side only when riding. Could clutch or, belt be the problem. Clutch engages smoothly with no acceleration problems. Especially noticeable on...
You need to determine whether the squeaking is being made by the engine, the primary, the drive, or the frame. While riding, pull in the clutch, does the squeaking stop or change in any manner? Is the noise there when the engine is running but standing still? Pull the clutch lever in and release, does the squeak change or stop.
If I had to say what I think it is, I'd say it's probably the rear drive belt is not tracking correctly due to the alignment of the rear wheel. Look at the rear wheel adjusters. They should be exactly the same on either side of the swingarm. Also, the belt must be tight. If not, a loose belt will make a squeaking noise.
Good Luck
Steve
Dec 26, 2010 | Harley Davidson FLHTCUI Electra Glide...
Sole Fitness F63 Treadmill Logo
94 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
