Question about Home
What does stk abbreviate in cooking measurements
  • 1,860 Answers
Posted on Mar 23, 2016
2000mg equals how many tablespoons?
0.4 TEA-spoons
Convert Milligram to Teaspoons
Milligram is a small unit of mass in metric system. The unit is abbreviated as mg. The unit milligram is most commonly used in medicine and pharmacy departments. A teaspoon is a unit of measurement of volume of a medicine or dosage which is equal to 5 milliliters. The unit is abbreviated as tsp. 1 mg is approximately equal to 0.0002 tsps. Use this online Milligrams to Teaspoons Converter to easily convert milligrams unit (mgs) to teaspoons (tsp).
https://www.easycalculation.com/unit-conversion/Milligram-mg-Teaspoons-tsp.html
Dec 07, 2017 | Office Equipment & Supplies
What does stk abbreviate in cooking measurements?
1stk=8tbsp
1lb=4stk
Not sure what it means but that's the equivalence
Apr 15, 2015 | Home
What's the definition of co ppm
"CO" is the abbreviation for Carbon Monoxide. It is an odorless, colorless, toxic gas that exists in automobile exhaust. "PPM" is the abbreviation for "parts per million". PPM is a standard used to measure gases, including CO. The EPA sets regulatory standards for how much CO may be emitted from automobiles. States have emissions testing programs to ensure these standards are met. If the CO in the exhaust of an automobile exceed the EPA's standards in PPM, then the vehicle will fail the emissions test and the vehicle must be serviced and made to meet the standard.
Nov 05, 2014 | 1991 Cadillac DeVille
1 lb 60z what is mean.pls answer me
What's the question?
Since one pound is sixteen ounces, 1 lb 60 oz is 4 lb 12 oz.
Aug 17, 2014 | Cars & Trucks
What is a maf pump
Maf is abbreviation for mass air flow sensor. And it is not a pump. It is a electrical sensor that measures the air flow to the throttle body.
Jun 09, 2014 | 2000 Ford Expedition
How deep is a fathom
A fathom (abbreviation: ftm) = 6 feet or 1.8288 metres
Jun 06, 2014 | Measuring Tools & Sensors
What is the difference between mg and mcg?
Milligrams are abbreviated mg, and micrograms are sometimes abbreviated mcg.
A milligram has 1000 times as much mass as a microgram.
Without more details on the mixture, there is no way to tell you about potency. Potency is usually measured in parts per million, or ppm. You would need two different substances to compare in order to come up with the potency of that solution.
If this is actually a drug question, as an "experienced" person, I suggest erowid.org for good information, and that you should know much more info than some rando on the internet can tell you in a chat box, before you go adventuring.
Oct 19, 2012 | wikipedia.org
Describe the rules of the metric table
General Rules for Abbreviating Units of Measure
  • Always abbreviate units when reporting numerical information.
  • Unless otherwise noted, singular and plural units are abbreviated the same.
    • Percent is not abbreviated, but is represented by the familiar "%" symbol.
  • Always put a space between the number and unit, e.g., 203.65 m, 457 um
  • pH: The proper method for reporting pH is to place the unit before the number (pH 7); never insert the word "of" between the unit and number and avoid splitting the unit and number within a sentence - they should always go together.
  • When do you abbreviate units vs. spelling out the unit(s) as word(s)?
    • abbreviate units when you are reporting a numerical value:
"The maximum depth achieved by the ROV was 124 m approximately 2.3 km due south of Pt. Lobos."
    • spell out the unit as a word when using it in a non-numerical context, e.g.,
"All measurements were made in millimeters unless otherwise indicated."
    • When starting a sentence with a number and unit, both must be spelled out as words (this is something to avoid, if possible), e.g.,
"One thousand six hundred and eighty-seven kilograms of ground beef were randomly sampled and tested for E.coli contaminants between 21 August and 21 November, 1995."
Feb 10, 2010 | Educational Insights Hows and Whys Of...
How to write down measurement ? i need to write down measurement numbers (radiun, width, etc)
Just write the number followed by the standard abbreviation for what it represents. What's the problem?
Jan 16, 2010 | Measuring Tools & Sensors
RED CONVERGENCE STILL OFF
Next step should be to check the fuse-resistors and low values resistors for open conditions as well the solder joints on them.
These parts are located near the STK ICs.
Also if you can measure the voltage that power up the STK's. If you do not have the schematic diagram, check the ICs data sheet to know where the voltage is getting to the ICs.
You may have to do the convergence adjustment manually after you replaced those parts.
Good Luck.
Mar 10, 2008 | Televison & Video
Home Logo
612 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
