Question about Coffee Makers & Espresso Machines
Salad master 10 cup jet-o-matic automatic coffee maker, made in usa, the m.h. graham corp. Doesn't perk long enough. Coffee is not complete, but coffee maker stops perking.
SOURCE: farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Posted on Feb 09, 2009
ginko
  • 19396 Answers
SOURCE: won't perk properly
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
rlmvbc230
  • 14 Answers
SOURCE: My stainless steel Mr. Coffee maker just quit
this is set up on a conventional mr coffee; if the hot plate is not as hot, it will not work, on the newer ones, a small chip could be getting hot, and like a car, it will either shut down or work part time. send it back to mr coffee, and they'll repair it, but it might be cheaper to replace it.
Posted on Aug 25, 2009
  • 176 Answers
SOURCE: Doesn't perk long enough
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
Posted on Jul 26, 2010
  • 176 Answers
SOURCE: direction to make coffee in Micro-perk coffee maker
Hi. Contact me for instructions callahanronald@att.net bobbyone
Posted on Aug 11, 2010
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
Salad Master Coffee maker. How much coffee for each cup? Also how do I keep grounds out of coffee? Thanks Aimee
A machine like the one in the link? That is an old style percolator. Mother had one when I was a kid. I am 63!
You will see in the diagrams that a filter paper is being used. With mother's the bottom of the strainer was fine so you didn't need one. Use a standard bowl type filter and if you can find circular filters with a hole.
One heaped dessert spoon is two cups. Supermarkets have a measure for sale.
Salad Master Coffee maker Google Search
Dec 19, 2016 | Coffee Makers & Espresso Machines
Saladmaster jet o matic percolator coffee maker manual
I need to find a thermostat for salad master 6 to 10 cups
perculator. Have any idea where I an purchase one.
Dec 13, 2011 | Coffee Makers & Espresso Machines
My bunn makes great coffee, but after 10 min in the cup it is luke warm. Could the initial temperture be set too low?
If by meaning the coffee pot, the bottom warmer maybe loose and dropped inside the machine.Normal brew temp is 195 degrees out of tank.There also may be problem with the hi-limit ,t-stat or element.
Dec 24, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
What does it mean when the brew light flashes?
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Mar 25, 2010 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Need a replacement carafe for our elite maxi matic 10 cup coffee
I have the same coffee maker & mine carafe broke too, The Carafe is $10.95 incl. shipping & handling, you will need to call Maxi-Matic customer service @ 626-912-9877 & they will e-mail you a order form to fill out. Hope this help.
Aug 31, 2009 | Maximatic Elite Cuisine EHC-2055 10-Cup...
May 22, 2009 | Faberware FCP280 Coffee Maker
Coffeepots not operating by not getting hot enough
Hi. Sue, Problem is you're buying China pot's. One of 2 things can cause that problem. The Thermostat or the keepwarm element. 9 out of 10 it is the thermo. The parts are not available in the USA. I have a eBay auction site. I have to make the thermo's out of USA ones. They are 8.00 plus 2.00 S/H. My eBay name is ron622c. If you want to stay with Farberware you can buy a used one or if you are lucky a new one. But don't buy a China one, Good luck. Ron
Jul 06, 2008 | Faberware FCP280 Coffee Maker
Coffee Makers & Espresso Machines Logo
91 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
