Question about Poulan 1630 16" Chain Saw
I have a model pp3816 poulan chainsaw that wont fire at the sparkplug
    Sniper:
  • 121 Answers
Check the coil wires. One of them may be broke. It all wires are in good shape and not broke, the coil may need to be replaced
Posted on Jul 11, 2009
SOURCE:
One of the bar bolts is turning with the wrench. how do i get it off?
That suxs remove good one place screwdriver under and near bolt that won't turn. Put good bolt BAC on hand tight. Apply pressure to scrwedrive trying to remove bad bolt. U have to take it to a machine shop or get that fixed good luc
May 25, 2014 | Poulan 2 Bar Bolts 2375 2175 Pp4218avx...
I have a poulan pp3816 pro 38cc that leaks gas out the muffler
Its either well flooded, or the carb needle is leaking, remove the spark plug, with the ignition switch off crank the engine to evacuate any fuel left in the cylinder, leave the machine for a couple of hours, re fit the plug and try to start useing no choke, if it still does not start, remove the spark plug again, rest it on top of the cylinder ( away from the spark plug hole ) crank the engine and check for a spark, if it has a good spark and the plug is soaked with fuel it could be a carb needle leaking, remove the carb, remove the metering cover held with four screws, replace the rubber tipped needle.
Jun 21, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need to replace all of the gas lines. Do I have
There is no reason to disassemble your saw, Please stop.
You can find a typical fuel system and a couple of suggestions here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
An IPL for a Poulan “PP3816 Gas Saw Type 2” can be found here - There are slightly different models. Please ensure this applies to your saw:
http://www.ordertree.com/modelinfo/PWE/PP3816-Gas-Saw-Type-2/75.PP3816-Gas-Saw-Type-2.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
If the above is not the correct model it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project. Any additional questions you may have can be asked below. I hope you found this most helpful.
Lou
Jan 31, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
No spark
Replace the spark plug then try this:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Your ignition is on the "Engine Assembly" detail (PP3816 Gas Saw Type 1) here:
http://www.ordertree.com/modelinfo/PWE/PP3816-Gas-Saw-Type-1/75.PP3816-Gas-Saw-Type-1.1.59.1.html
If not your saw you can find yours here:
Poulan.com
http://www.order tree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If I can be of more help please reply below. I hope this was helpful.
Lou
Jan 21, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My gas poulan chainsaw model# pp3816av wont crank or get fire at the sparkplug and leak oil in case bad from the bar
the firing part try new sparkplug [plug must be grounded] still not firring disconnect one wire from on off switch purviservin@gmail.com
Jul 10, 2009 | Garden
The trigger sticks in the open position on my pp3816. Can this be repaired or is a new hande required
Possibly gunk has accumulated inside the handle,preventing the trigger from moving correctly. Try spaying WD40 or other lubricant inside the handle around the trigger. That may loosen up the trigger. Also, try the WD40 on any part of the linkage that you can locate.
Jun 27, 2009 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Poulan 1630 16" Chain Saw Logo
159 people viewed this question
Top Poulan Garden Experts
roeb
Jay Finke
Jay Finke
dannydoesita
Are you a Poulan Garden Expert? Answer questions, earn points and help others
