The agitator isn't working properly. It starts by agitating normally, then only one direction and then stops. The motor is running, it clicks and spins normally
  • Washing Mach... Master
  • 5,323 Answers
No agitation?
SOUNDS LIKE ALSO CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
IF NO T THAT use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Posted on Apr 16, 2015
Kenmore washer will not agitate but will spin. Transmission spind free and motor was replaced. Could it be the capactor?
No very likely it will not be a problem with the capiciator,what it does is gives the motor a extra jolt of power when it first starts to get the motor running,so if the motor runs the cap. is working normally. Since it does spin yet wont agitate the problem is very likely going to the transmission. HOWEVER FIRSTLY THOUGH I HAVE A QUESTION; is both the upper barrel of the agitator AND the lower paddles not agaitating or is just the upper portion notturning while the lower paddles work??
If both the upper and lower section aren't moving the problem will probable be the tranmission
IF JUST THE UPPER PORTION ISN'T WORKING the problem will be the part called the agitator dogs, thats a fairly common problem with the dogs to be worn out and just the upper part of agitator not working....this tip i wrote will show ya how to replace the dogs if that is what turns out to be the problem. http://www1.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Oct 06, 2011 | Washing Machines
Will not agitate or spin. Have replaced the belt (was worn) but still wont. Fills fine. When I first put the new belt on I ran it empty (stopped it when it started agitating, moved it to sping, stopped...
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya. As for the spinning, you need to check the lid switch. It may be bad. It may be your motor drive since it doesn't do both. Have you had draining problems?
Feb 23, 2011 | Maytag HAV3460AWW Top Load Washer
The washer stopped spinning and agitating. The motor runs, the belt turns all 3 pulleys. The main pulley will turn the agitator by hand. When the 6 screws are not attached to the brake stator the machine...
HELLO THERE:
SYMPTOM: WASHER FILLS, BUT DOESN'T AGITATE AND/OR SPIN
1) Check the imbalance/lid switch FOR continuity. Check also the speed selector switch (if any), the water level and water temperature switches for proper operation .
NOTE: If any of the selector switches on the console are only partially pushed in, it may cause improper function.
2) Check for a broken or badly worn belt.
3) Check the motor rollers and tension springs for damage and the motor roller tracks for jamming. Any of these might cause the belt to be loose.
4) Check the appropriate timer circuits for continuity.
5) Remove the belts and see if the motor will start. If you hear the motor buzzing, but it doesn't start in either or both directions, test the capacitor (if any) and starting switch
If it does start with the load removed, turn the pump and transmission pulleys by hand, in both directions, to see which is locked up. If the pump is locked, If the transmission pulley is locked,. Note that the transmission pulley will normally be very stiff when turning it in the clockwise direction, as you look at the bottom of the washer.
Nov 14, 2010 | Maytag PAV2300 Top Load Washer
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Agitator stops working after 10 seconds
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 05, 2009 | Hotpoint GE VWSR4150DWW WASHER
Neptune washer will not go past the first wash cycle
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Won't spin
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken.
Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Last the huming may be the motor is sized! Done, finished!
This is not a do it your selfer job
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
