Question about Dyson DC35 Handheld Vacuum
Brush on a Dyson DC35 stops rotating. I cleared it of any debris, cleaned off the roller, no obstructions in the tube, and it kept doing it.
I replaced the vacuum head with a different one and it's still doing the same thing. So it's clearly not that, What's wrong with my machine?
This just happened to me, too. The brush stopped working after about 3 seconds when turning the vacuum on. I checked everything as suggested. Wand obstructions, battery contacts and washed the filter. No changes.
I finally realized that there were quite some dog hair at the little plastic wheel that drives the brush. This make me believe that dog hair increases the friction and stops the brush. Besides, when I took the brush out and run the vacuum without it ran without issues. So I started taking the brush apart (my warranty was already expired). I removed the plastic at the bottom, took the motor assembly out and then removed the little screw in the plastic piece driving the brush. With a pair if needle nose pliers I pulled the plastic wheel off (insert on part of the pliers into the screw hole and the other one on the outside shaft - pull carefully but with some force). Voila, there were quite a lot of hair burned up underneath increasing the friction. I removed the "hair o-ring" and after reassembling the motorized brush it works like a charm.
Posted on Aug 09, 2015
  • Official Brand Answer
  • 2,572 Answers
Hi Aaron, it's Jack at Dyson.
I'm sorry to hear you're having difficulties with your DC35. If the replacement motorised cleaner head hasn't resolved the issue, there could be an issue with the wand, main body or battery. We're happy to help you check for this, which should avoid you having to order further parts until we've determined which part is actually at fault. We can also confirm whether or not your machine is still covered under the Dyson warranty.
When you have your DC35 fully charged and easily to hand, please contact our experts so we can talk you through some simple diagnostic checks. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Posted on Apr 15, 2015
ukvacfan
  • 328 Answers
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Posted on Apr 02, 2009
  • 12 Answers
SOURCE: cleaned the brush bar but still not spinning DC14 Dyson
the belt is broke.
Posted on Sep 07, 2009
Vac Belts
  • 701 Answers
SOURCE: When switching the vacuum (DC17 Animal) over to
The drive belt has probably broken. You can get a replacement belt here:
Dyson DC17 Belt
Posted on Dec 05, 2009
  • 1619 Answers
SOURCE: Caught shoe string in roller brush, now will not rotate roller BR
Belt maybe streched and hardened from heat replace and try again.
Posted on Apr 15, 2010
  • 101 Answers
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Posted on Dec 20, 2010
I have a dyson vacuum cleaner and the and the brush roller will not turn so all it will pick up is what it can suck up.the roller is clean
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 24, 2017 | Dyson Vacuums
Dyson animal ball, brush stops rotating often. Restart vacuum, brush head runs very short time, shuts off on flat tile floor.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
Ava B.
Jul 12, 2017 | Dyson Vacuums
I have a Dyson DC50. The brush will not spin and nothing is obstructing the ability to rotate. Even when I try to vacuum and the rear wheels kick up, nothing happens where it normally should. HELP
Ava B.
Feb 05, 2017 | Dyson Vacuums
Dc35 brush head spins and stops
Ava B.
Jan 17, 2017 | Dyson Vacuums
The head of dyson 23 not rotating
https://www.thinkcrucial.com/search?type=product&q=dc23
Ava B.
Jan 09, 2017 | Dyson Vacuums
Dyson dc35 Brushes quit turning after a few seconds--motor keeps running. It does this consistantly. No red flashing lights.
https://www.thinkcrucial.com/search?type=product&q=dc35
Ava B.
Nov 22, 2016 | Dyson DC35 Handheld Vacuum
So I have a dyson dc35 multi floor and it was working great then i turned it off to empty it and the brush wouldn't spin anymore. I cleaned it charged it and still nothing.
Ava B.
Nov 04, 2016 | Dyson Vacuums
Have a Dyson v6 for several months. Roller brush stops turning a soon as I start to push forward after staring trigger. Examined & cleaned roller & surrounding head & find no objects interfering.
The Dyson V6 has an electric motor in the power head. The battery is in the handle unit. So power has to get from the battery head unit down to the motor at the floor roller brush. The way they do this is to send the power around the plastic debris cup that you empty, and then into the connector for the tube and out the bottom of the tube to the roller brush motor. Your problem is probably that there is a lost contact along the way. Try plugging the roller brush directly into the head unit leaving the tube out and see if it is intermittent or if it runs fine. In that case the problem is one of the contacts associated with the down tube. If the roller brush is intermittent even when plugged directly into the head unit, then the problem may be the connection associated with the debris cup. remove the cup and make sure the contacts are clean. Hope this helps. G
Oct 26, 2016 | Dyson Vacuums
Dyson dc 25 animal brush not rotating
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Apr 12, 2012 | Dyson DC25 All Floors Bagless Upright...
Dyson DC35 Handheld Vacuum Logo
1,190 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
