Question about Maytag NFW7200TW Front Load Washer
What does up for liquid and down for powder mean? do you slide the plastic tab down?
  • Maytag Master
  • 5,323 Answers
YES UP IF UR USING LIQUID DOWN IF USING POWDER
Posted on Apr 16, 2015
How does soap dispenser work? what does up for liquid and down for powder mean?
Liquid laundry soap (comes in plastic liquid container) uses the up. Dry powder laundry soap uses the soap that comes in a box, therefore not liquid. and uses the down switch slider control.
Apr 14, 2015 | Maytag NFW7200TW Front Load Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to change the faceplate of a samsung s7330
  • Locate the small plastic tab on the top of your Samsung phone, located in the groove between the faceplate the main phone body. This tab is very tiny, only about one-sixteenth of an inch wide.
  • 2
    Press on the plastic tab with your fingernail.
  • 3
    Continue holding down the plastic piece while sliding the faceplate off the top of the phone. The faceplate only slides off from the top, so don't try to force it in a different direction.
  • 4
    Release the plastic tab.
  • 5
    Line up the new faceplate with the top portion of your phone then slide it downward until it latches into place. You'll typically hear a soft click when the faceplate is secure. When properly placed, the new faceplate should not be able to wiggle or slide unless you press down the plastic tab once again
    Read more: How to Change a Samsung Phone Faceplate ' eHow.com http://www.ehow.com/how_5146822_change-samsung-phone-faceplate.html#ixzz17o6dpgG0
  • Dec 11, 2010 | Samsung S7330 Cell Phone
    I have ball bearings in tool box want to powder coat it will heat effect bearigs if i run it through 400 degree oven
    It shouldn't harm the metal bearings but it will burn off the grease which could affect you powder coat adhesion and sometimes those slides have plastic parts in them too which could melt -ruining the slides, can you remove the slides and then reinstall them sfter the powder coat?
    Jun 14, 2010 | Hand Tools
    Can only select channel 13 no other numbers respond. Channel selector only goes down, won't go up, volume control will only get lowers, will not always go down. Power switch does not respong. Have already...
    Did you use your remote a lot?
    Do some buttons work sometimes if you press them really hard?
    If it's a double yes and you've already cleaned the remote (the rubber pad with buttons and the circuit board with contact tabs), then the buttons are most probably worn out, which means they no longer make a good contact on the circuit board tabs.
    There's a repair liquid kit for remotes, i'm not sure what the brand name is or where to get it, in europe, conrad electronic was selling it some time ago, however, i make my own from benzene, rubber glue and grapphite powder.
    The other solution is either to find a new rubber button pad or to get a brand new remote...
    regards
    3rq8 (Triarcuate)
    Jul 23, 2009 | Televison & Video
    Detergent will not dispense
    generaly the detergent tray has a "gate" that needs to be moved to the top position for powder. (up for powder, down for liquid). This is the generic answer. if you verify the model number or list the model of your unit I will attempt to locate a users guide for you.
    Please take the time to give this solution a fix ya rating
    clarkco
    Mar 07, 2009 | GE WSXH208A Front Load Washer
    Hoover quattro system 1100 ab power jet as 110
    I had the same problem when i got my machine, if you slide out the powder and softener tray just behind the face of it on the right hand side you will see a white plastic tab about 2 inchs wide! That plastic tab slides out and has all the programme settings on it!
    Aug 08, 2008 | Hoover HC6 110M Front Load Washer
    Powder or Liquid
    . HE detergent is a must for these machines first and foremost. as a genral rule liquid detergent breaks down better in cold water, so performs better in washers(cold water rinses). powder breaks down better in hot water which is why its reccomneded for d/w's.that being said i dont really mind which is used where so long as your not experiencing cleanig problems, at that point its when i reccomend using the appropriateone. whirlpool has now reccomneded a product called AFFRESH, tablets that can be used to clean out you frontloading machine incase of residual build op and/or odors.
    Feb 28, 2008 | Whirlpool WFW8300SW
    Water leaking
    There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
    Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Maytag NFW7200TW Front Load Washer Logo
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
