Question about Hitron Car Audio & Video
My 2000 watt Hitron amp is on protection and I want to know how I can get it off protection
5 Suggested Answers
  • 631 Answers
SOURCE: 2000 watt legacy predator amp
Disconnect all speaker wires from the amplifier's speaker terminals and disconnect the RCA cables from the amp. If the amp still goes into protect, it probably has shorted output transistors.
Posted on Feb 17, 2008
  • 12 Answers
SOURCE: Its stuck on protected. I recieved the amp for my
whats the ohm rating of amp probally 4 what is the ohm rating for sub how many subs are you running how do you have them hooked up parallel or series is your wiring to amp right
Posted on Jul 06, 2009
SOURCE: 2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Posted on Jun 12, 2011
SOURCE: ok i have a hitron 2000 watt monoblock D class amp
theres a switch on you're hitron amplifier that'll say bridged or unbridged you wanna flip that switch while the amp and speakers are on and everything is hooked up but make sure you're bass is on minimum so you dont pop your subs once u flip that switch everything will work amazingly, the switch is between where your speaker wire is hooked up and where you have your power wire, you can't miss it.
Posted on Apr 09, 2012
Problem with amplifier equalizer HITRON
You would be better off replacing the unit
May 22, 2013 | Computers & Internet
Hitron hra-2500b amp turns on then turns off
Make sure that you are not over loading the amp. Example - if your amp is only rated for 8 ohm then you can not wire the speakers for a 4 ohm.
Jan 25, 2013 | Hitron HRA 2500B 2 Channel 500 Watt Mosfet...
Its stuck on protected. I recieved the amp for my birthday in 2000. It protected it self 90 days later. I needed an amp righr then so I went and bought a 600 watt jensen. I took the old one out of the...
Jul 06, 2009 | Car Audio & Video
How do i know what size fuse i need for a hitron hra 2500 amp?
im assuming you dont have the old one. typically it will be 20-50a. i recomend consulting the manufactures website.
Apr 25, 2009 | Hitron HRA-2500 250W 2CH Amplifier Car...
Need amp
Hi and welcome to FixYa,
It would be safe to use an amplifier slightly lower than the maximum rating of the speaker. In this particular case, 350 watts or lower would be just about right for each. If you are wiring the 2 subs in parallel and powering them with a single channel amp, then a 700 watt bridged would also work.
Good luck and thank you for using FixYa.
Apr 09, 2009 | Hitron 2 12in Subwoofers loaded in...
Application
I'm happy I can help a newbie. I remember when I was one and I'm happy to help you. First off, I nodiced that the fuse is only a 30 amp fuse. A quick way to see what is probably the max output of your amp is take the fuse value, in your case 30 and multiply it by the voltage you will be supplying it. Lets say you are just sitting with the car off the voltage would be 12ish volts. So your total assumed wattage is 360 watts. Which is an large amount less than the 1000watts listed. So watch out for that. Also, with subs you would want a mono-block class-d amplifier. If you need any more help at all, let me know. Good luck
-Andrew Hawkins
Aug 21, 2008 | Hitron HRA-4100B 4 Channel 400 Watt Mosfet...
8 ohm to 4 ohm
All you need to do is wire your 2 subs together in parallel. This means Hooking the positives of both subs together, as well as hooking both negatives together.
Your total resistance:
Rt = (R1 x R2) / (R1 + R2) = (8 x 8) / (8+8) = 4
A ---------------- + ------------ +
M >| >|
P------------------_--------------_
May 15, 2008 | Hitron HRA-2200B 2 Channel 400 Watt Mosfet...
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
2 12" Hitron 600w subs in a BandPass box
Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
Car Audio & Video Logo
67 people viewed this question
Top Hitron Car Audio & Video Experts
xxxxxx xxx
Are you a Hitron Car Audio and Video Expert? Answer questions, earn points and help others
