Question about Maytag NFW7200TW Front Load Washer
How does soap dispenser work? what does up for liquid and down for powder mean?
  • Maytag Master
  • 2,992 Answers
Liquid laundry soap (comes in plastic liquid container) uses the up. Dry powder laundry soap uses the soap that comes in a box, therefore not liquid. and uses the down switch slider control.
Posted on Apr 15, 2015
How to fix leak from soap dispensor
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up.
Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
Dec 07, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Why does Dishwashing solution not empty into dishwasher?
Sounds like the soap door is not opening. This is controlled by a relay in the door. This panel needs to remove to troubleshoot.
May 05, 2014 | General Electric Dishwashers
I have a whirlpool wfs 1071aw and havent used washing liquid before only powder...cant find my manual and when I put the liquid where I would have put powder it leaks soap out of the dispenser onto the...
You should have a little divider in the soap drawer , it needs to be moved into a different position for liquid ( holds the liquid until the cycle begins)
Mar 15, 2011 | Washing Machines
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap doesn't go out of dispenser
Make sure you are using a liquid or powder detergent made for front loading machines and has the HE symbol on the front. Also use warm water not cold some detergents may not dissolve completly
Aug 10, 2007 | Kenmore Elite 45986 Front Load Washer
Maytag NFW7200TW Front Load Washer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
