Question about Home
I would like to no what kind of snake this is. Black on top and black yellow white design in bottom
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
chillmaster
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
  • 162 Answers
SOURCE: the top screen is black
you hold select while turning on your DSi that should fix it
Posted on Jan 02, 2011
  • 4 Answers
SOURCE: my dsi xl is top
http://www.elitepvpers.de/forum/consoles/759258-tut-how-fix-code-death-evil-0000fe00-error-ndsi-xl.html
Posted on May 02, 2011
SOURCE: wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Posted on Sep 19, 2011
A small,1.5 - 1.75 inch black snake with yellow band around neck
There are two kinds.. I was always taught.Black on yellow kill a fellow....Black on white spare a life ...Try searching Corn and Cora maybe coral snake..... You will find the difference
Aug 14, 2017 | Cars & Trucks
What snake id black with yellow strips
Might be an eastern ribbon snake or common ribbon snake
Eastern Ribbon Snake
or a Plains garter snake
Plains Garter Snake
or maybe you can do a google search for a snake black with yellow strips¿
May 30, 2015 | Reptile
Kind of snake with black body whitestripes dimaion?
Eastern kingsnakes are large -- 36 - 48 in (90-122 cm) -- shiny-black, smooth-scaled snakes with white or yellow chain-link bands that cross the back and connect along the sides. Because of this pattern, this species is also referred to as the chain kingsnake.
Sep 06, 2014 | Reptile
What snake is black with yellow stripes?
The Plains garter snake has either an orange or yellow stripe down its back and distinctive black bars on its lip. The stripe normally starts at the head and continues all the way to the tail tip. Lateral stripes are located on the third and fourth scale rows and are normally a greenish-yellow color.
Plains garter snake
Sep 02, 2014 | Reptile
A brown headed snake with light colored patches outlined in black. One on back of the head as the rest of body
Click the link and when ready, click images.
http://lmgtfy.com/?q=A+brown+headed+snake+with+light+colored+patches+outlined+in+black
Jul 14, 2014 | Televison & Video
Wiring an electric water heater
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Apr 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 07, 2010 | Car Audio & Video
Wiring a TPH553 Surface Mounted Jack by RCA.
REF: wikipedia
Feb 17, 2010 | Computers & Internet
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Home Logo
76 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
