Question about Pool & Spa
2008 Great Lake spa. How do I get it out of sleep mode. We just installed a new control panel about two months ago.
  • 2,963 Answers
Must be some bad connections. I'd review the install instructions and user's manual.
Posted on Apr 15, 2015
Need to print out control setting or hole manuel for 1996 great lake spa
Good Luck ; (
If you need control system operation assistance, find out the mfg'r and locate the proper numbers and search that way.
Spa manufacturer manuals are very difficult to get.
Nov 01, 2014 | Great Lakes Spas Spa Cover - GL-1SE
How do i get my spa out of sleep mode
It would help to know what spa you have, but the most common controls out there are manufactured by Balboa Instruments. If your top-side controls only have four buttons try pressing "temp" or "set" button followed by "light" button. Once there, pressing the "light" button usually cycles through the programming. On some models the "temp" button must be pressed to confirm the selection.
http://www.balboawatergroup.com/Topside-Spa-Panels
Sep 14, 2014 | Pool & Spa
The instrumentation panel says "SL" and the spa isn't heating.How do I get it to heat again?
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
Aug 27, 2013 | Balboa Instruments Duplex Digital Panel 2...
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Mar 13, 2013 | Balboa Instruments Pool & Spa
My balboa spa says sl and isn't heating up
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
At first Ithought it was my monitor, so I went and bought a new monitor. Hooked up the new monitor and monitor is still blank. It turns on Windows XP and then a little box comes up "sleep mode"...
Have your tried booting into "Safe Mode" ? minimal video drivers are used, allowing you to go in to
  • Control Panel
  • System
  • Hardware
  • Device Manager
  • Display Adapter , Uninstall your old driver
  • Reboot , this allows yours system to clear the registry
  • Re-install video drivers for new card
Feb 24, 2011 | Computers & Internet
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Another "No Audio output device is installed"
Actually the problem that you have is the power management. Go into Control panel then the power settings. Make sure to turn off system standby. The reason that it is not installed after it comes from sleep is that it is not reenabling. THe computer turns off the component during sleep.
Feb 06, 2009 | Microsoft Windows Vista Ultimate Edition
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
Pool & Spa Logo
97 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
