Question about Navico Simrad AP16 Autopilot for Inboard wRam Cyl to 11 cuin
Turn on normally, go to press auto.... nothing
  • Navico Master
  • 693 Answers
Hi Ty
This sounds to me like a cabling problem. There is enough "horsepower" to turn the unit on, but the increased current required to actually run the thing isn't as robust as it needs to be.
I would start by checking the connections at the panel or battery. Make sure these are absolutely pristine. (i.e. Clean and tight) Pay particular attention to the terminals and/or crimp connectors, whichever are used. It doesn't take much corrosion here to render the autopilot inoperable. Let me know how you make out.
-Steve
Posted on Apr 15, 2015
Testimonial: "lookin a little further, after i turn the head unit on in standby, the only other button that seems to work is the 1deg. port button and the 1deg. strb button. the motors move as they should."
How to reset windows on is 350 lexus 2007
(a) Turn the engine switch on (IG).
(b) Halfway open the power window by pressing the power window switch.
(c) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 1 second after the power window is fully closed.
(d) Check that the AUTO UP/DOWN function operates normally.
If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time. If not normal, follow the steps below.
(1) Disconnect the negative battery terminal for 10 seconds.
(2) Connect the battery terminal.
(3) Turn the engine switch on (IG).
(4) Halfway open the power window by pressing the power window switch.
(5) If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time.
(6) Turn the engine switch on (IG).
(7) Halfway open the power window by pressing the power window switch.
(8) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 12 seconds after the power window is fully closed.
(9) Check that the AUTO UP/DOWN function operates normally.
Feb 05, 2017 | 2007 Lexus IS 350
Tip
How to enter Factory settings on GNR TS700 (Black/Silver) 17" LCD monitor
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
on Dec 31, 2009 | Computers & Internet
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
How do i stop the DEV auto power off frkm turjing my tv off?
I am having this problem and It is happening on 2 different brand tv's. I have had Foxtel on both tv's for years and never had a problem until I moved, I got the Foxtel reconnected at my new address and it started. I have IQ on 1 tv and standard digital on the other. If anyone could help that would be great.
Feb 21, 2015 | Televison & Video
Wont turn on
Mine doesn't turn on either.
I keep pressing the power button but nothing happens.
Press it longer than 3 second.
Press it harder than normal.
Also press the reset button at the back.
Nothing works it just won't turn on.
The power LED does turn on, but the heater and the rest of the display doesn't work.
Mar 30, 2014 | Tefal Ultimate EZ Clean Pro Deep Fryer
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
Lg e700sh monitor out of shape i need the settings of original shape
try factory settings
- Press Menu
- Exit as normal
To reset colour:
- Choose Factory 2
Jun 14, 2011 | LG Flatron F700B 17" CRT Monitor
PROGRESSIVE LIGHT WAS SET BY MISTAKE, AND IT HAS BEEN SET ON AUTO HOW CAN I SOLVE THIS PROBLEM BECAUSE THERE'S ONLY A BLACK SCREEN AND SOUNDS THAT COMES ON.
According to the operating instructions (page 97), Progressive Scan can be cancelled (or turned off) by pressing and holding PAUSE (on the main unit) continuously for 5 - 10 seconds, until the progressive indicator goes out, or turning it off in the setup menu. Your recorder should now be back to normal interlace video output. I recommend that you check your setup menu after this procedure to make sure nothing 'AUTO' is set, that shouldn't be set, and subsequently turning off any function that isn't required.
Apr 30, 2011 | Sony RDR-VX515 DVD Recorder/VCR
THE CAMERA GOES DEAD VERY SOON WHEN IT TURNS ON. IT HAS GOOD BATTERIES.
Hi, I've scoured the 3 page manual and come up with this.:-
There is nothing wrong with your camera. The camera has a built-in power saving
feature that turns the camera off after 30 seconds of inactivity (default setting) to
conserve battery power. The auto off time setting can be changed in the set up menu.
Changing the Auto Off Time Setting:
1. Set the camera to Camera Mode.
2. Press the Menu button to display the main menu.
3. Press until the Setup is highlighted.
4. Press to enter the Setup submenu.
5. In the Setup menu, press to highlight “Auto Off Time”.
6. Press to enter “Auto Off Time”. Press to highlight the time you want.
7. Press the OK button to save your selection.
Hope this helps
Mar 05, 2010 | Concord Camera Eye-Q 4060AF Digital Camera
Camera
PRESS AND HOLD DOWN THAT BUTTON TILL IT TAKE PICTURES or PRESS IT FOR 2sec AND leave
Nov 26, 2007 | Sony Ericsson K750i Cellular Phone
Navico Simrad AP16 Autopilot for Inboard wRam Cyl to 11 cuin Logo
244 people viewed this question
Top Navico Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Navico Boating Expert? Answer questions, earn points and help others
