Question about Samsung HW-C500
No sound from speakers, but yes from sub. Grounding issue?
HW-C500 set / AH64-04721A receiver The sub works when it should. All of the other speakers randomly cut out (all together), leaving just the sub playing. Sometimes it works perfectly, other times I only get bass. The problem lasts for a while whenever it cuts out. I read elsewhere that this unit has grounding issues. It's all in a power strip with the tv, apple tv, record player, receiver, sub, etc... Everything is hooked up correctly. What inside the receiver could be failing?
  • Samsung Master
  • 5,056 Answers
Grounding issues are just simply earth connections that are either loose or are badly soldered. Sometimes with bad soldering a knock on the unit can make it play. It's just a question of going inside and looking - with a lens sometimes - at soldering joints - wire connections and screws fixing. Random cut outs certainly sound like bad soldering problems etc. The only other cause is heat sensitive devices, which shut down when too hot. But I wouldn't jump to that conclusion just yet.
Posted on Apr 28, 2015
3 Suggested Answers
hfmiles
  • 1165 Answers
SOURCE: Hi there, I bought this
I think you would have to use the tv remote control to change the input signal from the dvd receiver to the digital tv receiver. If that doesn't change anything, see if there is a setting for external speakers when not using the dvd receiver.
Posted on Feb 13, 2011
bshldn
  • 736 Answers
SOURCE: my dvd player is hooked up to the samsung
What you have to do is select the proper item on the receiver since that is what you have the dvd player connected to. Pressing bd/dvd on the receiver is not necessarily the right thing to do. All receivers have an input or source or function button that will enable you to choose the correct area where your device is connected. The way you have this hooked up may not be right but first things first. You will need to have a movie playing in the DVD player so that you see the numbers advancing. Go to each input/source/function on the receiver until you hear the DVD. Ok great! Now getting the picture is a little more tricky so please follow along carefully.
The cables going from the DVD player to the receiver: The cables should be connected to where it says OUT on the DVD player or hdmi out from the DVD player to one of the receivers INputs. Once that proper connection has been confirmed make sure the receiver is connected to the television for both video and audio. You must have a video cable as well as audio cables between the television and the receiver or an hdmi cable. If it is not connected to the television in this way that is the problem right there. In fact you probably have a cable going from the television's audio OUT going INto the receiver. In order to see your DVD player you will also need to connect the receiver's video OUT to the television's video IN.
You will need the television's remote to be able to change the source/input/video/aux on the television. You might be able to change it with the cable box remote by pressing tv and then input/source/video.
ALTERNATELY: You can connect the DVD player's Video OUT directly into the television's INput. The DVD player's Audio OUT cables would be connected directly to the receiver's IN.
Either way you will have to choose the correct input on the receiver as well as on the television itself.
Posted on May 16, 2011
No sound or standby/links light working on my samsung Wireless Subwoofer HW-D450 sound bar.
If no lights at all come on, then the sub is completely dead and probably needs to be replaced.
Apr 17, 2013 | Samsung HW-D450 Crystal Surround Air Track...
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
No sound when hooking receiver to subwoofer using standard red RCA cable. Do I need a subwoofer cable?? I have turned my tuner subwoofer to YES, powered up receiver and subwoofer but nothing.
Probably not if it takes RCA input, but the receiver needs to be informed of the sub's presence and hw you want to share low frequencies among the rest of the speakers and itself. Then you need to set the relative levels using test tones, which also proves the sub works.
http://www.retrevo.com/support/Sony-STR-DH700-Receivers-manual/id/23341dj691/t/2/
Page 102
Set the subwoofer to YES (Page 43)
Jan 17, 2011 | Sony STR-DH700 A/V Receiver
I have just bought the samsung ht c555 home cinema kit connected it to the the tv all is working well when playing a5.1 dvd but ihave no sound out of the system when on ordinary tv how do you get all 5...
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
Dec 24, 2010 | Samsung Audio Players & Recorders
Can't get the subwoofer to work when the fronts are set LARGE?
The manual implies that 'subwoofer=Yes' is independent of the rest of the speaker settings, but that it would be set AFTER selecting the other speaker configuration from the list of 11 possibilities.
Jun 08, 2010 | Sherwood RD-6106 Receiver
I was given a Cerwin Vega LW12 by a friend. It works fine for some music at any volume, but with certain types it has a popping coming out, even at low volumes. Switched speakers and still happens....
phreewillie,
If you are certain that the problem is not with the speaker(s) the problem then sounds like an issue before the amp.
Did your friend have this issue? If yes, the problem is with the built in amp/crossover. If no, there is some kind of problem in your location.
The amp will not produce the popping sound even if the the amp has a problem electronically. The problem could be improper voltage, line noise, wire resistance or a grounding issue. The first two would be eliminated by using a line conditiner with a built in surge protector. The resistance and grounding issues would be associated with the wire connecting the sub to your electronics. It could be simply the cable connecting the sub has an issue, try swapping it with one that you know works fine. Are you using in wall wiring? Try using like stated above, a short known good patch cable. Sometimes the wire of choice during a installation will not work for that amp. Try taking that in wall cable out of the loop. I have seen just this problem in the past due to the type of wire used. A low cost way to eliminate the voltage issues is to try a different source of electricity by taking the sub to a friends house and see if you can reproduce the problem there.
-Chris
Jan 19, 2010 | Cerwin Vega LW12 Subwoofer
How to switch on Sub?
surround and subwoofer may not work if there is an additional graphic equaliser operating.
1. check in your receiver speaker setting ensure your speaker setup doesn not have subwoofer set to NONE. this will block any signal to your subwoofer socket.
2 when you select your surround sound setting setup, ensure you select the speaker mode you want, if there is a multicontrol knob, cycle through the choices
select subwoofer mode and set it to yes.
if you have set-up small speakers S in your speaker settings then it could be that subwoofer is set to yes automatically if you have large speakers L, subwoofer has to be set additionally in the subwoofer setting.
3 test subwoofer on alternative device to test it is working ok
consult manual on enjoying surround sound and adjusting the speaker settings.
Nov 16, 2009 | Sherwood R-945 Receiver
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Samsung HW-C500 Logo
110 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
