The motor for the brush on a shark SV75 14 hand held vac fell out when I dropped it as repairing the small plastic wheel for the belt. Thanks
The motor fell out when dropped and cant get the connections back in.There are prongs on the ends of the wires and looks to go in the openings under the motor but cant get them in. The motor runs when checked
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Might just be running on the spring u need to get carbon brush in or the spring will reck armature
Posted on Apr 27, 2015
  • 91 Answers
SOURCE: I have a Kenmore model
repl/ lid switch need to remove top panel and complet cabinet to repl./ that broken pc
Posted on Jan 04, 2009
  • 68 Answers
SOURCE: motor not running in Asko 10504 washing machine
The motor might have burned out. Another possibility would be a partially fried control board.
Posted on Jan 17, 2009
  • 686 Answers
SOURCE: Maytag washer SAV2655AWW - pulley wheel replacement
WHICH PULLEY FELL OFF YOU HAVE 3 OF THEM ONE IS A "IDLER PULLEY FOR DRIVE BELT" ANOTHER IS "PLASTIC HELIX, TRANSMISSION DRIVE PULLEY" AND LASTLY IS "PULLEY FOR TRANSMISSION DRIVE" GO TO www.repairclinic.com ENTER MODEL NUMBER AND SCROLL ALL THE WAY DOWN TO THE RED 100 CLICK IT AND LOOK FOR PARTS 550204, 889619, AND 889618. YOU MAY HAVE TO WORK ON THIS FROM THE BOTTOM TO GET TO THE PULLEY. IF YOU HAVE A MECHANICALLY INCLINED FRIEND, IMPLORE HIM OR HER TO HELP YOU UNLESS YOU CAN GET THE TUB OUT AND WORK YOUR WAY DOWN
Posted on Apr 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Washing machine not spinning
The pin is a shipping pin and serves no purpose after the machine is set up. These machines comes with a plastic strap through the back panel to hold components in place for shipping. There are plastic cups that the pins fall into after the strap is pulled.
Ignore the pin.
Your no spin problem is a stripped out direct drive coupling between the motor and transmission.
It is a easy fix.
Use the attached video as reference to change out the part.
Posted on Apr 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 does not spin (sounds like working & coupler is good)
If the coupler is ok then the next thing to check is the brake/ basket drive cam driver, the ear breaks off on em and won't release the brake. You must remove the agitator and drop the tranny to check itffbcc2d.jpg
Nothing is difficult about repairing the washer. I have repair photos HERE
Posted on Mar 13, 2010
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
Oct 17, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
Why does my tiger shark motor run and peller spins but wheels do not turn
if the wheels are not turning, there is a good chance the drive belt is damaged. this can be repaired
Jun 14, 2014 | Aqua Vac Tiger Shark
Brush won't spin on my shark navigator.
Maybe not the same issue, but my roller brush would only work intermittently. I had to take apart the main housing and clean the two contacts (female side) that connect to the lower brush assembly. Now it works like new.
Oct 30, 2011 | Shark Navigator Bagless Upright Vacuum
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
I need a new roller bar or beater brush for infinity vacuum
Hi There,
Here's a link to that part on our website if you haven't found it already:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Apr 14, 2010 | Euro-Pro NV31 Infinity Vacuum
Shark v1510 How do I replace the belt?
remove the outside sliding cover... remove 2 screw in from of housing, and also the screw holding the wheel on the brush head cap side of the housing. Once screws are rmoved, you can remove brush head cap and belt cover. Pull down on belt cover to remove. It is held by screw crossing the top of the cover from the side. Belts are hard to find, but can be ordered from shark web site (2) for 7.95 and shipping.
I had the same problem. Some one should stock these belts in the states, because Shark outsources thier call center to India, which sucks. It took 20 minutes on the phone to communicate through the noise and language barrier just to order a belt!
Oct 23, 2009 | Vacuums
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
