Question about Samsung Galaxy Cell Phones
I cant get the sim card to fit into the holder, it is impossible without wrecking my sim card
  • Samsung Master
  • 2,045 Answers
Which model and SIM card size you're struggling with?
Posted on Apr 14, 2015
Why my phone say no sim card when the sim card is in the phone
did you cut the sim yourself , if so you messed it up , what phone do you have, iphone ? the no sim means the phone does not see it , you have to make sure it is cut right to fit the sim holder look on youtube to see if you can fix it ,
Mar 04, 2015 | T-Mobile Concord
How do you put the sim card in the iphone 4
Sim card and it's holder is located at right side edge were you can see a small whole,to release the sim holder,you need a needle or safety pin to push it inside until the holder comes out then pull it,you need a micro sim that fit's the sim holder,If you want to use your old sim,you can modify it by tracing the pattern and use a cutter for fitting the particular size.
Jul 23, 2011 | Apple iPhone Smartphone
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
I am using nokia 5130 .but it was some problem,some times my mobile showing sim card regestration failed
Perhaps there is some loose connection of the SIM card to the SIM card holder and contacts. So remove the battery and the SIM card., Use a paper to polish the SIM card contacts and the contacts on the holder. Make sure that the SIM when placed fits well into the holder firmly and in place , If not you can lift up the contacts very carefully so that the SIM never loses contact.
If this wont solve there are errors in the main board which might need more attention with help from Nokia care.
Mar 28, 2011 | Nokia 5130 Cellular Phone
My sim card not installed
It may be a case of wrong cutting of the micro sim. Since the iPad uses a microsim, you haveto make sure that the sim card is cut perfectly. Do not use a pair of scissors, you have to cut it specifically using a micro sim cutter. Or you can check if the placement of the sim card is correct. Sometimes, the card seems to get loose thus making it unreadable by the iPad.
Mar 07, 2011 | Apple iPad 64 GB 3G Tablet PC
Hoe to insert/reomeve sim card?...
The position of the SIM card holder depends on your phone model. It might be placed under the battery or on the side of the phone. Before inserting/removing your SIM card, turn off your phone and make sure no charger is connected to the phone. Insert your SIM card according to the illustration that you find close to the SIM card holder.
Note: Without a SIM card, you can't make or receive calls. In some countries you can make emergency calls without a SIM card.
May 20, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Installing the 1gb card
Remove the sheel backside of your phone
remove the battery
now you see your sim-card
you place the sd-card just at the right side of the sim-card
lift the mediacard holder
insert the sd-card into the slot in the mediacard holder so that the metal connectors on the card will align with the metal connectors on your phone when the media card holder door is closed
close th media card holder door and slide the media card door away from its hinges to lock it
put back the battery and shell and you done!
If you still dont know, here is an demostrator how your phone works
http://demos.blackberry.com/8310/na/us/gen/
Good luck
Dec 07, 2008 | SanDisk 2GB microSD Memory Card
Insert sim card
that s because there may be some problem in the sim card holder or the sim card holder is in loose contact ...
just open the handset and remove and clean the sim card holder with some alcoholic solvent and refit that correctly and then get your mobile phone working for the sim cards ...
any doubts you can reply me
rate my solution ..
have a nice day
Sep 07, 2008 | Cell Phones
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
