Question about Dell OptiPlex Computers & Internet
I need wiring for the front panel switch and LEDs for Dell UP453 Mother board
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Posted on Apr 15, 2015
  • Dell Master
  • 3,320 Answers
This is a Supermicro board. Use the info in the amazon page to search Supermicro's site for the manual. Dell Optiplex 320 DT MT Motherboard MH651 CU395 UP453 TY915
Posted on Apr 14, 2015
  • Dell Master
  • 2,045 Answers
Check those on eBay if Dell doesn't give you a chance.
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
I have a Dell Dimension 1100 that will not power on. It is getting power to the mother board. Could it be the power switch? and how do I replace it?
http://support.dell.com/support/edocs/systems/dim1100/EN/SM/adtshoot.htm#wp1059100
use the diagnostic LEDs to determine the fault
Jan 19, 2011 | Dell Dimension 1100 PC Desktop
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Wire came loose on pavilion xe 734 that supplie power to hard dir
First of all these wires don't supply power to HDD. These wires are for indicator LEDs on the front
panel of the cabinet. One wire `power sw' is to switch on the system from the power button on front panel. `power led' wire is of the power led on the front panel. All these wires will be connected to the cluster of pins on one corner of the mother board. If you can see it will be indicated & printed near the cluster of pins on the mbd, that which pair of pins is meant for what connector. Try to correlate the names on connector with the print on the mbd.
Jan 06, 2009 | HP Computers & Internet
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Installed an Upgrated Mother Brd,in my Hp Desktop Tower,but the power Switch receptacle in the New Mother Brd has 16 pns
You need to track the wires from the case front panel to thier locations: one will be your power switch, one your reset, one hard drive activity light, and one your power light. You want to note and label which light or switch they go to then go to the new motherboards manual and plan which wires need to go where.
the front panel switches : reset and power switch- these are momentary switches so it doesnt matter which way they go.
hard drive activity and power light- these should have a colored wire and a black or white. the colored wire will be your + side.
Nov 08, 2008 | Computers & Internet
Dell motherboard
If you mean the front panel power switch the connectors are in most cases located in the bottom right corner as below:
Note that your wire setup can be difrent form the image.
If you need more assistance let me know, I'm here to help
Apr 13, 2008 | Computers & Internet
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
Computers & Internet Logo
95 people viewed this question
Alun Cox
