Question about Ezip Trailz Electric Bike
Me ezip is making a clanking sound when I engage the throttle. Nothing looks broken or messed up and its running but something is wrong. Help??
  • Joshua Brown
    Joshua Brown Apr 15, 2015
    OK so there is slack in the drive chain but can't seem to get it tight just by sliding the mount back
  • Paul Bade Apr 15, 2015
    Some slack is actually good; the chain and sprocket wear more if it is too tight. Generally, you should be able to move the chain about half its width up and down between the sprockets. If the clank is intermittent, check the chain for stiff links. If it happens every time you put a load on the system, look for slop between the sprockets and hub or motor gearshaft.
    Top Expert:
  • 47,775 Answers
Have someone else look when you start out it isn't the stand dragging is it from broken spring
Posted on Apr 14, 2015
  • 1,587 Answers
Check for a loose motor mount. Also look for excessive slop or backlash in the chain drive. You may be able to identify the problem by lifting the bike so the rear wheel is off the ground and rotating the wheel backwards by hand while watching the motor assembly.
Car makes clanking sound from exhaust
Could it be u'r heat sheildwith a broken mount resting on the exhuast pipe getting really hot and makeing that sound as it cools down??
Apr 04, 2016 | 2004 Pontiac Grand Am
Throttle linkage
Is it brand new? How could it get messed up just sitting around? Cable broken?
Mar 21, 2015 | Craftsman Tiller Operation Manual...
I have a ezip 450 electric scooter doesn't run.I
Check the brake micro switch and brake coil resistance plus all wires in this area.
Oct 09, 2014 | Health & Beauty
What is wrong with it?
the throttle cable has been adjusted to far foward making choke engagement hard and the govenor speed needs to be adjusted down it set to fast
Jun 06, 2014 | Husqvarna 21" Lawn Mower with Honda GCV160...
Milwauke 6527 Sawzall motor runs but something is wrong with the internal workings
This may be of no help but I believe that the reciprocating shaft is oblong on one side and more of a round hole on the other. It has to go in with the oblong down engaging one of the two wobble plates. It would be item 51. Also if you removed the wobble plates (37, 38) the shorter of the two (38) goes towards the rear. Also make sure the spacer (item 64) is in there and not messed up. Also check needle bearing item 4 and make sure it fits well on the gear shaft.
Milwaukee 6527 diagram
Jul 28, 2012 | Milwaukee tools Milwaukee Tool 6527-6
4WD seems to work fine in 4HI with a rattleing noise that sounds like it is continuing to attempt to engage, put it in 4LO and the truck will lock the drive train after about 5 feet of driving and will not...
Sounds like you have something broken in the transfer case. Two wheel drive is transmission to rear end. 4x4 mode engages the transfer case, possible broken tooth on a gear, or bad synchronizers
Oct 27, 2017 | 2003 Chevrolet Silverado 1500
Noise in brand new GE dryer
HI not the gas line that should be fine there is something stuck in your blower fan i would say if it went wrong after one hour they should come right back to fix it
Jul 13, 2009 | GE DCVH515GF Gas Dryer
Strange noise!
My 2005 GMC 2500HD (8.1 lt) had the same problem. I just had an exhaust leak fixed today. The right front manifold bolts were broken and the manifold was warped. The repair was 6.5 hours labour plus gaskets, seals, bolts and the manifold machining (parts were $130 CDN).
Jul 08, 2008 | 2002 GMC Sierra 2500HD
Ezip Trailz Electric Bike Logo
95 people viewed this question
Top Ezip Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Ezip Cycling Expert? Answer questions, earn points and help others
