Question about Powerware 9390 UPS System
Powerware 9390 UPS error configuration and circuit breaker battery check
UPS displays (circuit breaker battery check ) after I changed the battery circuit breaker . but unfortunately the UPS no longer Demare . still function in bypass mode and displays "error confuguration " and " battery breaker check ".
    Problem Solver:
  • 17 Answers
Check in breaker have contact and relay that allow to ups recognise the breaker and battery voltage
Posted on Jun 04, 2015
  • 5 Answers
9390 Requires a UVR type battery breaker. Unfortunately a configuration error will require a service visit from a technician. The proprietary service software will have to be used to reset this.
Posted on May 05, 2015
  • 195 Answers
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 37 Answers
SOURCE: rectifier and heatsink temperature sensor not ok
it could be your uPS given the problem the mosfet might be spoil... as the temperture is high because of the transformer is not given the clean current to bypass the systems and the there not much air filter out from the ups depend on the condition of the room might be too warm.. there a higher chance was the mainboard problem well u check the sensor lst and also try to unplug and plug bk to restart the sensor... if it will not slove the problem check with the vendor to come down and check..
Posted on Jun 05, 2009
  • 25 Answers
SOURCE: Powerware 9330 15kVA UPS
did you fix this problem?
Posted on Jul 11, 2009
  • 4 Answers
SOURCE: my ups has is faulty i need a circuit diagram to fix it
I had a DC bus fault error displayed.
So I unplugged battery, then turned on UPS. It said Batt disconnected of course.
So when I plugged in the batt while the UPS was on, and held the power button for a few sec, the UPS displayed Batt testing.
After a few moments it was back online and had no faults!
Worth a shot.
Posted on Dec 09, 2010
  • 39 Answers
SOURCE: Battery Packs for Powerware 9355 UPS
If you battery packs are all at 130volts DC, then all of the packs will have become dead, and the batteries are not recoverable. Your battery DC bus voltage on a Powerware 9355 20 to 40kVA rated UPS is nominal 432 volts DC - 36 batteries in series in each string at 12 volts DC per battery. If batteries go below 10.5 volts DC each, or 378 volts DC bus voltage, no amount of charging will recover these batteries. You should not be recycling the DC battery breaker, unless you felt the battery breaker was faulty. The UPS would have given you an alarm message of either battery breaker Off, Charger Failure, or Low DC Bus Voltage long before the these batteries failed.
The battery test will not proceed if the batteries are dead.
Posted on Feb 11, 2011
How to reset configuration error of the UPS 9390?
This error can only be cleared by the Eaton technician with their laptops. If this is a new unit it HAS to be factory started or your warranty will be void.
Apr 02, 2015 | Powerware 9390 UPS System
What is the password for a powerware?
You will have to consult the user manual for the default password. Usually default passwords are admin/admin.
Oct 16, 2013 | Powerware 9390 UPS System
Notice: UPS ON BAYPASS, ERROR CONFIGURATION
Need to configure upon initial startup
May 21, 2013 | Powerware 9390 UPS System
Message comes up on restarting reads configuration error. What is the cause and possible solution?
There is alot of possibilities on this on. Most likely it is in your input or output. You may have a 208V or a 480V input but your UPS may be programed for 240 or another voltage. I have the manual and all the knowledge you need. Email me at ericpettingill@hotmail.com
Sep 16, 2011 | Powerware 9390 UPS System
I had an alarm on 9390 which read : "Battery Test Fail". What would possibly cause it and how would I best prevent it from reoccuring.
This error indicates that the battery packs are no longer able to supply the expected run time or load capacity that the UPS needs. The batteries will need to be replaced.
May 11, 2011 | Powerware 9390 UPS System
I WOULD LIKE TO BUY A NEWPowerware 9330-40kva UPS UNIT, COPLETE WITH BATTERIES .how much would that cost?
It's unlikely that you will be able to get a new one. The 9330 was discontinued many years ago though Eaton continues to service these models and provide replacement parts/batteries. I suggest that you call 800-356-5794 to see if Eaton has a partner that has any complete systems still in stock or in service inventory. The new UPS units are the 9355 and the 9390: www.eaton.com/9355 and www.eaton.com/9390 These new units are more compact, are more energy efficient and incorporate more advanced technology for monitoring and communication.
Mar 11, 2011 | Powerware 9330 40 (A40401110031112) UPS...
My ups has is faulty i need a circuit diagram to fix it
Worth a shot.
May 20, 2009 | Powerware 9120 UPS System
Rectifier and heatsink temperature sensor not ok for 9390 powerware ups system. When i switch on the 9390 ups a message appears which reads check rect temperature sensor and check heatsink temperature...
May 18, 2009 | Powerware 9120 UPS System
Powerware 9390 UPS System Logo
641 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
