Question about Health & Beauty
AMC on one side 500/125 on the other side - Health & Beauty
  • 2,963 Answers
Take to your druggist, they know pills and their coding.
Posted on Apr 15, 2015
I have a gift card for AMC Theatres, can they be used for Cinemax? Are Cineplex & Cinemax the same theaters?
Details of terms and conditions for AMC Theatres follows:
Gift cards are usable up to balance only to buy goods or services at any AMC Theatres®, AMC Loews®, AMC Showplace, Cineplex® Odeon, Magic Johnson and Star theatres in the U.S. Not usable to purchase gift cards. Not redeemable for cash unless required by law. Not a credit or debit card. Safeguard the card. It will not be replaced or replenished if used without authorization. If lost or stolen, replacement card with remaining value requires original proof of purchase. AMC Card Processing Services, Inc. ("AMC CPS, Inc") is the card issuer and sole obligor to card owner. AMC CPS, Inc. may delegate its issuer obligations to an assignee, without recourse. If delegated, the assignee, and not AMC CPS, Inc., will be sole obligor to card owner. Purchase, use or acceptance of card constitutes acceptance of these terms. For balance or other customer service inquiries, visit any AMC theatre, log on to amctheatres.com or call 1.800.255.0311.
Feb 12, 2015 | Audio Players & Recorders
How can I install an AMC 360 engine into my 1965 rambler classic with a 287 engine?
what I did was removed the 287 engine installed an AMC 360 .In order to do this you have to get an borg warner m11 bell housing from 67 to 71 .amc used borg warner transmissions until than. So you put the m11 bell housing on to the m8 transmission and get the motor mount for the AMC 360 engine
Feb 10, 2015 | AMC Cars & Trucks
Picture of firing order 232 sixcylinder
Here's NEARLY what you're looking for:
http://www.autozone.com/autozone/repairguides/AMC-Coupes-Sedans-Wagons-1975-1988-Repair-Information/FIRING-ORDER/FIRING-ORDER/_/P-0900c1528008508e
...but 1965 Jeeps didn't have 232s in them, so that's not a 1965 Jeep 232. In '65, Jeep was a Kaiser company, not an AMC company... and the 232 was an AMC engine that was first installed in Jeeps in... 1972, I believe, alongside the 258 and the 304 (for Renegades). Before AMC bought Jeep, some CJs were shipped with the Buick V6, though.
Aug 01, 2014 | American Air Filter Rambler American Dog...
Amc manuals
Go to the AMC Eagle Den and sign up for the forum, then ask this question there. Great place if you want to keep your Eagle up!
Welcome to the AMC Eagle Den
Jul 10, 2014 | 1985 AMC American Motors Eagle
Amc manuals 1977
You can acquire this manual from most any PepBoys store. If you'd rather, just type in your google box "1977 AMC firing order".
Naturally you'd put the engine size,6 or 8 cylinder with displacement, right after AMC in your typing. When you click the search button it will show you your firing order. Google is your friend.
Jul 03, 2014 | 1974 AMC Gremlin XP
Interchangeable rear amc eagle
Rear axles on all AMC Eagles interchange with each other, regardless of year. Jeep Cherokee (compact XJ models) will interchange, but the shock mounts are different - Jeep mounts must be cut and welded, at least on one side. Make sure the axle ratio is the same as the front axle ratio, or the same as the axle you're replacing.
Jan 11, 2014 | 1984 AMC American Motors Eagle
Where is resistor for blower located on 1977 amc gremlin .thank you
in the heater box eather under the passenger side of the dash or right hand side of car at the firewall
Sep 18, 2013 | AMC Gremlin Cars & Trucks
My 85 egale amc leaks on the right side of the valve cover what do i do
Replace the valve cover gasket and use black RTV to seal it.
May 10, 2013 | 1985 AMC American Motors Eagle
Cj7 rear
Jeep Axle: AMC 20
Front Axles
Dana 44
Dana 30
Dana 27
Dana 25
Rear Axles
Chrysler 8.25"
Dana 35c
AMC 20
Dana 30
Dana 60
Dana 53
Dana 44
Timken
Dana 41
Dana 23
Jeep Axles
Upgrades
Factory Options
General
-->All AMC 20s have a 8 7/8" R&P and use a 29 spline shafts. The AMC 20 R&P is 3/8" bigger than the Dana 44, but it uses smaller shafts, smaller axle tubes, and the CJ version comes with weaker two piece shafts. The AMC20 uses a 29 spline shaft where as the later Dana 44 uses a 30 spline shaft. The AMC 20 housing tends to flex a lot which can cause breakage. This can be remedied by welding the tubes and/or adding gussets. The reason the AMC 20 flexes more than the Dana 44 is the shorter differential housing and smaller axle tubes. It's other flaw is the CJ version uses the two piece axle made up of a hub and a shaft. The hub end tends to break off under load which has created the market for one piece AMC 20 axle shafts. Unfortunately, the shafts are expensive ($350+ USD) and in some cases a special bearing must be used.
amc20co_.gif -->Identifying the gear ratio of an AMC 20 is a bit tricky. Dana axles normally have a tag on the left of the diff cover with the gear ratio at the time of build. The AMC axles have a code that has to be looked up in a table. The code is stamped on the housing boss to the left of the diff cover right near the axle tube. Good part about the stamp is it tends to stay readable longer than the tag, but you have to know the code. Since there are conflicts between what a code means for a narrow track and what it means for a wide track, don't count solely on the code to identify an axle. Bring a tape measure or know the source of the part. Specs Narrow Track AMC 20 Code Gear Ratio Diff Type AA 2.73 Open DD 2.73 Trac-Lok BB 3.31 Open CC 3.31 Trac-Lok A 3.54 Open N 3.54 Trac-Lok GG 3.73 Open Q 3.73 Trac-Lok L 4.10 Open M 4.10 Trac-Lok Wide Track AMC 20 Code Gear Ratio Diff Type D 2.73 Open DD 2.73 Trac-Lok B 3.31 Open BB 3.31 Trac-Lok A 3.54 Open AA 3.54 Trac-Lok H 3.73 Open HH 3.73 Trac-Lok C 4.10 Open CC 4.10 Trac-LokThe Trac-Lok is a limited slip differential. You may have to scrape away a lot of mud, paint, and rust to uncover the code. If you can't find the code on the rear, check the tag on the front axle. Both axles should be geared the same. The R&P ratio ranges supported by the carriers are 2.73 and 3.31-5.13. The 5.13 gear ratio is not available for the Dana 30 though, so it is rare to see it. 4.56s are the lowest common ratio between the Dana 30 and AMC 20. 5.13s are available for the Dana 44.
CJ AMC 20 The CJs used two versions of the AMC 20, the narrow track from '76-'81 and the wide track from '82-'86. Both versions use keyed, two piece shaft/hub design and 5 on 5.5" wheel bolt pattern. Supplies of AMC 20s were exhausted in 1986 and some Dana 44s were used instead in the last of the CJ-7s.
From 1976-1978 a larger 11x2" drum brakes was used on the AMC 20. After 1978, a 10x1.75" drum was used.
SJ AMC 20 The Wagoneer and full size Cherokee also used a narrow and wide track version of the AMC 20. Both SJ versions used once piece shafts and 6 on 5.5" wheel bolt pattern. Since the length and bolt pattern is different from the CJ version, the SJ shafts are not compatible without resplining and redrilling. I've never heard of anyone going to the trouble.
Model/Version Spring Pads Wheel to Wheel Years AMC 20/CJ Narrow Track 36" 50.5" '76-'81 AMC 20/CJ Wide Track 36" 54.5" '82-'86 AMC 20/SJ Narrow Track AMC 20/SJ Wide Track Last modified Friday, 03-Dec-1999 21:48:34 MST
[ Jeep Tech Main Page | Terry's Jeep Page ]
Copyright © 2001, 2000, 1999, 1998 JEEPTECH.COM
All Rights Reserved, All content with exception of private works and
corporate trademarked logos are property of Jeeptech.com
Jun 06, 2009 | 1985 Jeep CJ7
Health & Beauty Logo
138 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
