Question about Honda Garden
Can anyone show me where the carburetor springs attach on the Honda gx160 for throttle control on a northstar pressure washer
  • 4 Answers
SOURCE: Can't start the Honda GX160 5.5 HP Electric motor
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Posted on Apr 27, 2009
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
mrrichardlbo
  • 59 Answers
SOURCE: pink vinyl tube under carburetor has fuel-smelling drip
no look to see if the clamp it on good it may have a pin hole in it best thing to do is relace it any auto store will have it...Good Luck
Posted on Aug 16, 2009
  • 151 Answers
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Posted on Dec 24, 2009
  • 15 Answers
SOURCE: honda powered gx160 model pressure washer wont start
Did you drain out the fuel before you stock it? If you didn't, you may need to clean the carburetor or replace a new one because the fuel inside has become a kind of stick varnish. You may take a look at following link to see how to change or replace a carburetor. http://solosmallengine.blogspot.com
Posted on Jun 08, 2012
Honda gx390
All the GX series engines I have dealt with have had governor rods that connected to a pivot on the throttle plate separate from the actual throttle control although this can vary from application to application since different Pressure washer makers do make some modifications to suit their specific needs and applications I have yet to run across this being changed, so I would say no, not likely.
Aug 01, 2014 | Garden
5.5hp GX 160 only runs flat out wont idle
carburetor throttle plate stuck open or spring off/ stuck on governor assy.
Jun 16, 2014 | 5.5 HP GX160 Engine
Revs really high
The gx160 has flag control on air intake to carb.
The flag is spring loaded to return to idil .
the spring has came off/ the cable has bunched preventing free movement.
long nose vice grips and gently reline.
Jun 09, 2014 | 5.5 HP GX160 Engine
Northstar Pressure washer starts and runs but dies when throttle is opened up
is this a v-twin engine or has the unit been stored for quite some time with fuel in carburetor.inspect fuel jet and tube for restriction.
Jul 28, 2013 | Garden
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
Northstar PW shuts off hot if washer is moved. Honda engine
Being petrol driven, it may have a mercury kill switch which puts a ground on the ignition circuit stopping the engine if you move it. Perhaps for safety in case you overturn the unit somehow.
Apr 08, 2010 | Northstar Pressure Washer 3000 PSI
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Apr 12, 2009 | Honda 8 HP Engine
Garden Logo
41 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
