Question about Garden
Were i can order and purchase a spool string piece replacement part for a Kawasaki KHS750AC hedge trimmer
    Top Expert:
  • Garden Master
  • 41,378 Answers
That is called the recoil starter and usually from a dealer take it in they might be able to fix
Posted on Apr 14, 2015
SOURCE: changing spool on weed trimmer
useless
Posted on May 10, 2008
  • 4 Answers
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Posted on Aug 07, 2008
SOURCE: can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
Posted on Jul 02, 2009
  • 76 Answers
SOURCE: replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
Posted on Jul 16, 2009
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
How do I change the string on a wheeled weedeater brand trimmer
Purchase precut pieces of string. Check the dealer or or big box store for the correct part. The precut string is easily clipped in. Remove the old piece by pushing back and lifting up on the piece until it comes loose. Put the new piece in the slot and pull it forward to seat it. Repeat for the other side(s)
Oct 19, 2014 | Weed Eater Wheeled Weed Trimmer 961720006...
Replacement of Cutting Line! How to do? anneodello
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 21, 2009 | Black & Decker Garden
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
How to change the string
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How do I replace the line on the spool?
Jim
Jun 27, 2009 | Garden
How to string a st3812b string trimmer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 26, 2009 | Garden
Describe string replacement on ryobi trimer
Jim
Jun 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Describe string replacement Troy- Bilt TB5755SS
Jim
Jun 23, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Adding trimmer line to spool on husqvarna trimmer-two strings
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 19, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
