Question about Bosch Drills
How do you remove the keyless chuck on a Bosch PSB600 RES drill?
  • Bosch Master
  • 3,287 Answers
Here's a link to an exploded view:
Bosch PSB 600 2 0603338003 Spare Parts
If you need more help - you should contact Bosch directly:
Contact Bosch
Posted on Apr 15, 2015
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
Require a 10mm and a 13mm Male-fitting Keyless Chucks
I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
Apr 04, 2017 | Drills
I have a rotozip 20 and the new keyless chuck just does not work. Am I doung something wrong?
Try not inserting the bit all the way in until it bottoms- it should not bottom. Also make sure it is the correct size range for the bits you have.
Feb 10, 2012 | Bosch Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
Bosch keyless chuck stuck
Make sure you try it in both directions.
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
Drill is stuck in chuck, and cannot be removed.
try using two sets of mole grips one on the small par tof the chuck and one on the large and try turning it with them it should come out
Jan 22, 2010 | Bosch 1/2" 6.5 Amp High Speed Drill With...
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Jan 17, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
Drills Logo
403 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
