Question about John Deere Garden
Wll the engine slide far enough forward to replace clutch on john deere 4010?
    Top Expert:
  • John Deere Master
  • 10,875 Answers
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a John Deere travelling sprinkler model
You can go to the following:
http://www.gilmour.com
There is an 800 number to call and you can also obtain a manual by selecting "Watering/hose end"
select "sprinklers" then "traveling". There you can download an Owners manual that has a parts breakdown in it
Posted on Nov 03, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
How to remove fb460v engine
the Kawasaki engine removes pretty straight forward (bolts out , cable off, wires unhooked, etc) , the only difficult part is removing a well worn in power take/off clutch from its shaft , this will take some care if you need to reinstall it
but I will say unless its a total loss (cracked) ive rebuilt enough of them while still in the tractor , the only part you cant replace doing it that way is the bottom oil seal and the crank shaft (its stuck into that clutch I was telling you about )
Sep 14, 2015 | John Deere Original 130 160 165 175 180...
How to replace pto clutch on John Deere x320
Removal and replacement fairly straight forward, you just need to prevent the engine crankshaft from turning. This can done either holding the flywheel or using a piston stop. Also some clutches have a set of flats that a 1-3/8 open end wrench will fit.
When reinstalling the center bolt torque to 50-55 ft-lbs. Also make sure the anti-rotation device is engage into clutch assembly or it will rip the wires out at the first startup.
Apr 07, 2015 | John Deere Garden
Need to fix UJ joint on John Deere 6410 between clutch and quad range
well ph it's your choice either the engines gotta move forward or the rears gotta go back , lucky it's only gotta move 10 inches as the shaft is splined so it'll slide off
personally Id move the rear ooh and your gonna need a overhead gantry or crane to do it rated for 5 tons at least
Feb 19, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere 4010 wiring schematic,diesel engine 24volt starter 12 volt charging systems need to rewire the starter ,voltage regulator,series/parralell switch
Call me, or email me there are so many options, I would like to know exactly what you need. Solutions are simple, I have worked on AC and DC vurrent all my life and even have some designs on youtube, and have taught seminars for Delco, Leece-Neville/Prestolite, and designs for A/P and Twin Roter. Shmburns@yahoo.com
Apr 01, 2011 | John Deere Radiator 4010 Gas And Diesel ()
John Deere 318 blades won't engage once it gets hot.
Check the clutch gap in the front of the machine (the one that engages the belt) by tightening or loosening three lock nuts around clutch. Tightening decreases gap/ loosening increases gap. Note: do not tighten too far as it will result in clutch drag or lockup! Stop when its just starting to touch then back off slightly. Also without a proper charge on the battery the magnetic power for the clutch is altered and not strong enough to engage clutch when hot. Find out why battery light is on.
May 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do i replace a fan belt in a John Deere 1140 .
Loosen the alternator bolts and slide it sideways until the belt can be taken off it.Once you get the belt off the pulleys you need to remove the stub shaft that goes from the motor to the pump,loosen the bolts and slide it forward with a pry bar.
Nov 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
JD push mower doesn't have enough power to throw
I would have a compression check done on the push mower,if it has bad compression the engine needs rebuilt or replaced. As far as the bent bracket,if you can straiten it thats what I would do,mabey get a torch an heat it first.
Aug 02, 2009 | Peg Perego John Deere Farm Tractor and...
Sprinkler will not move forward properly
I have 2 John Deere 4010 traveling sprinklers and they both do the same thing. I took them apart and the plastic worm gear has flat spot on them. I am having difficulty finding replacement parts.
Mar 08, 2009 | John Deere Gilmour Traveling Sprinkler -...
Garden Logo
90 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
