Question about Garden
Only runs with choke on.Clean tank new lines,and filter.cleaned float bowl,carb appears to be new.
MTD Yard machine Model 13AO772H755, Briggs 15.5 42 inch deck
    Sergeant:
  • Garden Expert
  • 187 Answers
Tracking down fuel problems.
NOTE:The MTD Yard machine Model 13AO772H755, Briggs 15.5 hp engine does not have a fuel pump.Ignore all references to the fuel pump.However the rest of the fuel pathway should be checked just the same.Watch the video.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling
  2. Is there a cut off valve at the gas tank? If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look at least 1/2 full of fuel.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
  4. Consider my own experience when my engine to quit in the middle of a mowing job: I was mowing along on my LA145 (200 hours on it) when it slowed down and died. Before it died, it acted like it was losing power. It thought it was only firing on one cylinder. I waited about 20 minutes and it restarted after a lot of cranking and some priming. I made a couple more mowing passes; the same thing happened again.
    I knew this mower was in top running condition. There were no engine misses, no backfires. It was not abnormally hard to start. The carburetor was clean, the coils were good, the plugs and fuel filter were recently changed. Lifting the hood, I noticed the fuel filter was nearly empty. It should be ½ full, or more. I pulled the hose off the tank side of the fuel pump and saw there was no fuel flow.
    Gas should gravity flow from the tank to the fuel pump, if the tank has a good supply of fuel. I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
    The problem repeated itself several times last summer. Back at the shop, I used compressed air (turned down to 20 psi) to blow the line clear. The problem reoccurred this spring. I used the same method to clear the line.
  5. Do your self a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank. Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started. I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger. Once you have a good fuel flow out the line to the filter, put on a FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  6. Check the fuel pump. The fuel pump system on the twin Koehler and the Twin Briggs (and others) are almost identical. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. . Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
  7. Note: My engine was starting hard and dying in the field this year (March 2015). While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump. It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  8. Many systems have a fuel shut off solenoid. This is a small cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on. If it does not click you will have to replace it or track down an electrical problem.
  9. If this has not solved the problem you may have to remove and disassemble, clean, or rebuild the carburetor at this point. You may have water, dried fuel (varnish) or trash in the carburetor bowl. Before removing and disassembling the carburetor try draining the bowl. Or, take the bowl off, careful not to drop the small parts inside. Clean the bowl and replace. I often remove the bowl on small engines and save the hassle of a complete carb removal.
NOTE: Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info and I will walk you through the next step. Tracking down a spark problem; yes, your problem could involve the coil or any part of the ignition/spark system. (Not as likely as fuel)
Posted on Apr 15, 2015
My 13.5 ho b&s surges heavily but smoothed out when blade/ deck is engaged or when I apply choke. I've twice cleaned carbs and still now working. I ran in garage with no air filter to elimina
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 19, 2012 | Mtd Garden
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Jun 05, 2011 | Mtd 22" Yard Machine Push Mower
My MTD Yard Machine Lawn Tractor suddenly chokes out after warm up. If I drop the deck and get some resistance, it sputters and quits. I can keep it running a bit with the choke, but I just cant keep it...
need to remove float bowl and clean it and pull the jet in ctr out and clean it also, there should be fine small holes in it you barely see sometimes and if it has a rollover solenoid ( electrical solenoid in float bowl clean it as well ) so that ir actully moves up and down as you cycle key from off to on. also check your fuel filter strainer in carb , its a little screen most of the time in carb base on top part, lots of time this will partially plug up also and of course check your needle and seat while you are there! should take care of your fuel problem. If you have an external fuel pump I would also check to make sure it is pumping by pulling hose off carb and rolling eng. over, should squirt gas out.....good luck
Apr 15, 2011 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Have a mtd yard machine riding lawn mower with a 15.5 ohv engine when using must use choke to keep running why?
This is because the gas is not flowing easily through the carburetor. This is usually due to some old gas gumming things up. First, replace the gas filter (if there is one). If that doesn't fix it, it usually works to drain the gas (discard it if it's more than a few weeks old). Then take a little fresh gas mixed with a little carb cleaner (about 2 parts gas to 1 part carb cleaner - about 1/4 cup total). Run the engine on that. If it doesn't improve, repeat up to 3 times. If that still doesn't fix it, you will have to clean out the gas tank, the fuel line, the bowl on the carburetor, and the needle valve that is operated by the float in the bowel. Clean all this and reassemble.
Aug 09, 2010 | Yard Machines Garden
Briggs & Stratton 6hp yard machine with 21inch cut. Not getting fuel. I replaced a bad fuel line and now no fuel! If I take the air filter off and spray fuel into the carb it runs until I quit.
The fuel bowl needs to be removed and a new float and needle needs to be installed. The float "floats" in the gas bowl raising the needle, letting fuel into the carb. The repair kit cost about $5 and easily replaced. The float is attached with a pin and the needle fits on the float.
May 12, 2010 | Mtd 22" Yard Machine Push Mower
Mtd 22" yard machine staryts and dies using prospray.
Remove the float bowl again and remove the BRASS Jet in the bottom of the venturi throat. Clean the pin hole of the Jet so that you can see through it. DO NOT force anything through it. Just clean it. Underneath the jet is the venturi tube itself. It is also unscrewed with a screw driver. Remove it and clean all ofthe holes in it. Then reassemble tube and jet in to the venturi. Check the BOWL NUT for 2 holes. If the holes are clogged your engine will suffer from a lack of fuel. Lastly check that you have FUEL flow from the tank to the carb. If the tank outlet hole is clogged you will also have a lack of fuel problem.
Apr 09, 2010 | Mtd 22" Yard Machine Push Mower
3 Hp Tecumseh lawn mower wont stay running?
Probably a carburetor problem. Old fuel, tiny amounts of water, plugged jets or a totally plugged air filter will cause that. Another option may be the throttle linkage is either unhooked or bent.
Remember to shut off the gas tank or empty it or plug the line before opening a carb or removing the carb.
Carb first, on the bottom is a float bowl held in place with a bolt that is hollow and is also a fuel jet. Remove the sediment(float) bowl and make sure it is clean, make sure the gasket on top is not damaged.Make sure the float moves freely up and down and the needle valve is not stuck. Make sure nothing is bent or shows rub marks on the float. Clean the needle valve and all orfices in the carb by spraying carb cleaner through them.The "bolt" that holds the float bowl is usually brass and hollow in the center with two tiny holes that are horizontal, if the center or the holes on the side get plugged - the engine will not run, it will only run until it uses up the gas that seeps into the center. Remove any gaskets first as carb cleaner will cause rubber to expand and get very soft. It is best to usually remove the carb to do a thorough cleaning.When every thing is clean reassemble and reinstall the carb. Clean the air filter thoroughly with some solvent or gasoline, and let it dry (foam filters) for paper filters, blow them clean from the inside using compressed air.
When all is back together, check to see the wire linkages are in their proper place and that they move freely.
Also ensure the choke is not on and that it works properly when it is started. Occasionally also this problem may be caused by a defective primer bulb if it has one. Usually if defective it will either leak or not work. Some are made with a tiny hole in the end, covering it will cause the engine to speed up.
Aug 30, 2009 | Mtd 22" Yard Machine Push Mower
Yard machine mtd 123cc mower stalls after starting it runs for a few seconds and then stalls. Previous to this it only ran on choke but when you took the chock off it stalled also. Now it stalls even when...
dirty gas. the fuel bowl likely has junk in it which plugs the jets as soon as it starts. you may get luck just emptying the carb bowl but a good carb clean and new gas will do the trick. (dump out the old gas
Aug 16, 2009 | Mtd 22" Yard Machine Push Mower
Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
May 21, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
