The arm that inserts the records into the carridge is in the upright position and will not go back down. It is obstructing the carridge from moving. How do I fix this problem?
When I tried to play a selection, the carridge tries to move but can't. Then an error displays on the digit readout. I removed the carridge to see what the problem was. All I saw was that it was a spring loaded insert arm, but couldn't figure out what was holding it down before that is not holding it down now. Did something break that I could not see or is whatever moving this arm back down not getting information from the operating computer.
  • 12 Answers
SOURCE: Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Posted on Sep 28, 2007
  • 112 Answers
SOURCE: Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
Posted on Jan 22, 2008
reddevil6
  • 1673 Answers
SOURCE: No vacuum suction during normal floor cleaning operation
That door is called a valve door, and it may have broken, part #38718013. Or the valve arm, rear broke, part number 38719048. The spring part # is 38358001. Usually it is the valve arm that breaks. You would have to take the top cover off, then you can see the parts.
Posted on Jan 29, 2008
  • 395 Answers
SOURCE: I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Posted on Feb 03, 2008
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
Why won't our arm on our record player advance to play record on auto control? Lifts, moves back and returns to original position.
Try adjusting the counterweight on the back. Average weight setting is 1 gram. most high end RPs have it and it's a 'turn clockwise to increase' deal.
If it's a cheapo, there may be something interfering with the arm. possible a spiderweb inside! or??
Aug 17, 2014 | Audio Players & Recorders
RCA VLP37H needle arm won't advance to play record...moves backward, then seats down again
You will probably have to take the bottom off to see what is happening inside. The thing could have been tampered with by someone try to fix something. So it's not something that you know was previously working. With a bit of luck it might need a bit of grease to get it going. But you never know with a second hand model!
Turntable arm not moving across record?
Try, without any record on the table, if you can move the are, to the centre of the table. If you feel anything that is holding the arm, try to find out what it could be. Never use force. Also look inside if you can't find a clear obstruction on the top of the table. If you should find anything, don't bent, or don't break anything. Let a technical skilled person look why the obstruction is there and where the "thing" should be so the aren can move free. Perhaps you ned the obstruction for something only a few centimetres to the left or the right.
Jun 26, 2014 | JVC Audio Players & Recorders
Oven latch will not open
Sometimes the latch arm is bent causing the latch release not to clear the hook on the door. If the arm goes under the front it is probably bent. Carefully pull the arm back toward the locked position and try to bend it back a small amount and see if the door will open after moving the arm back to the open position. If that fails sometimes you can insert a bent coat hanger between the door and the latch hook and move the latch enough to unlock the door. I hope this helps
Nov 28, 2013 | Ovens
Have a DC25, I can not return the handle to the upright position. Nothing appears to be broken
Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
dcramer531_17.jpgdcramer531_18.jpgdcramer531_19.jpgdcramer531_20.jpgdcramer531_21.jpgdcramer531_22.jpg
Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Printer carridge
Turn the printer off. Then move the print head back to the center with your hand and turn the printer back on.
Feb 16, 2008 | Dell Photo 964 All-In-One InkJet Printer
Printer carridge
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
Alternatively, if you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Should you decide to have a go at cleaning or re-fixing the spring, the first thing to do is to download the service manual from:
http://www.mediafire.com/?m6ouftizois
- so you can see how to remove the case etc. Let me know if you are going to do this because, when you have got the printer covers off etc, you will some tips on how to get this blasted spring back on again!
If you decide to do these things, report back for all of us to benefit from your experience.
Nov 23, 2007 | Epson Stylus Photo 820 InkJet Printer
Tape Won't Load
something is blocking the mechanism and not letting it load or the mode switch is bad and the mechanism dosent know where it is. These camcorders are common for this type of problem and these days Im sorry to say that most places charge an arm and a leg just to look at them. good Luck
May 25, 2006 | Samsung VP-L700U Camcorder
127 people viewed this question
 Grubhead
Grubhead
