Question about SewShop.com Singer Model Quantum CXL Instruction Manual
Why wont the needle on my sewing machine move?
I can hear the motor running and i can't even move it with the hand turner
    Top Expert:
  • SewShop.com Master
  • 52,047 Answers
Belt broke perhaps
Posted on Apr 14, 2015
My machine froze/seized up while I was sewing. Does it need a new motor?
Not necessarily unless you have burnt it out trying to make it go.
Its most likely clogged with cotton fibres underneath the needle plate and the bobbin. Give it a good clean out.
Oct 17, 2014 | Singer 7256 Fashion Mate Sewing Machine
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
Jul 03, 2014 | SewShop.com Singer Model 900 Futura...
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
PFAFF SEWING MACHINE, USED MACHINE, JUST BOUGHT. MACHINE SEEMS TO BE VERY CLEAN, HOWEVER MOTOR ON OUTSIDE TURNS FURIOUSLY, BUT INTERIOR SHAFT WILL NOT TURN. I have cleaned and oiled, can this be fixed...
Try holding the hand wheel firmly and turning the smaller knob in it's center clockwise until it clicks. To fill bobbins, you have to stop the needle from moving by turning that knob counterclockwise and it sounds like that's the problem.
Aug 12, 2011 | Vacuums
It dose not sew, and when it dose the bobbin tangles up and lets out too much thread
The bobbin goes into the holder in what would appear to be the wrong direction ie, the thread doubles back. If this is correct, the bobbin tension might be too low, there is a screw on the bobbin holder to set the tension.
Jan 24, 2011 | Singer Vacuums
Sewing machine needle not moving up and down
Well there are many things to check (causes) -
Upper thread has run out. Presser foot is up.
Bobbin winder shaft was left in winding position.
Buttonhole lever was not lowered when machine was placed in buttonhole mode.
Anyway you may try the steps below to correct this (Solution) -
Replace empty spool and thread machine.
Lower presser foot.
Move bobbin winder shaft back fully to left.
Lower buttonhole lever.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Vacuums
Machine will only sew in reverse
Open the bottom of the machine. Ther is a rod running from one end to the other. It needs to be loosened and turned 180 degrees. You may have to retime the machine when you are done.
Apr 30, 2009 | Vacuums
SewShop.com Singer Model Quantum CXL Instruction Manual Logo
70 people viewed this question
Top SewShop.com Vacuums Experts
Ron Lake
Andrew Taylor
Andrew Taylor
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
