Question about Vizio Televison & Video
The screen will not power up but the vizio light will light up
My tv Started smoking and then the screen turned off and now the screen will turn on but when I plug in the Tv the Vizio Icon on the bottom of the Tv Will still light up Orange but the screen will not power up
  • 23 Answers
Yes, don't know if still looking for answer be nice if could get model number but sounds like u may either have power issue or on some of the visio sets especially older models if lcd the inverter boards may have went bad causing a service mount chip to burn a whole in itself which means no backlight no screen but unless u can take back off and ck this is only one of a few possible solutions, hope this may help.
Posted on Apr 20, 2015
  • Vizio Master
  • 681 Answers
Hi Christian,
Your Tv gave smoke and still the Vizio icon is lighting up means the TV's initial system is ready to start but the next stage has gone bad. I do not know how good you are with electronic repairing. If you can do something, open the back cove, see the damages and let me know situation or consult someone who can do it for you. Good luck.
Posted on Apr 15, 2015
The power button on the corner of my TV lights up but when I turn on the TV the VIZIO logo lights up but immediately turns off and the screen stays black. What could be the problem?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 27, 2016 | Vizio M190MV 19 in LCD TV
Have Vizio TV, powers on, but blank screen, no backlight
Its probably damaged the board that powers the backlight in the surge. Repairs on this depending on the size of the TV might out way the cost of replacement. I
Dec 05, 2013 | Televison & Video
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
My vizio started smoking then screen turn black
Unplug the set and do not for any reason plug it back---unless skilled have the set looked at by a technician or a repair shop.
Best guess without seeing set would be power supply problem but it could b e in another area.
May 17, 2012 | Vizio E420VO 42 in. LCD HDTV
My WW42L Vizio smokes and doesnt turn on. The vizio light will turn on and thats it. Is it repairable?
Likely power supply but UNPLUG SET AND DO NOT TRY TO USE AGAIN UNTIL SOMEONE OPENS IT AND EXAMINES IT.
Apr 03, 2012 | Televison & Video
TV WILL NOT TURN ON BUT VIZIO LIGHT IS ON
The Service Plan from Walmart is an "extended plan" on top of the manufacture warranty. Your Tv is still under warranty from the manufacture.
Here's a link to get the info you need to get started on a warranty claim:
http://www.vizio.com/support.aspx?id=1588
Jun 27, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
137 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
