Question about ProPlumber 3/4-in Female Brass Yard Hydrant Valve PPYH-3
Remove stuck plunger inside pipe. - ProPlumber 3/4-in Female Brass Yard Hydrant Valve PPYH-3
Choke stuck yamaha tt r125 lwet
Hi is it your choke cable? replace it if it is.
If its the choke plunger on the carb you need to remove the carb and remove the plunger or yamaha calls it starter set and clean the inside where it attaches usually it will hve some oxidation deposits in there so it good time to clean the whole carb what i use is a carb cleaner called brand name (Sea Foam) does a great job.
Oct 24, 2012 | Motorcycles
Buttons on our concealed dual flush cistern have stuck in, water constantly running into pan?
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Jul 08, 2011 | Plumbing
Stucked lens
removing stuck contact lens of the hard kind with a plunger. This works well and is incredibly efficacious. You moisten the cup of the plunger and place it right on top of the lens. The lens should be simply removed because it will stick to the plunger.
Apr 17, 2011 | Casio Exilim EX-Z750 Digital Camera
The drivers side door will not open at all, from the inside, or outside, it used to
THE PLUNGER, IE CENTRAL LOCKING MOTOR IN THE DOOR IS STUCK IN THE LOCK POSITION. WHEN THE CENTRAL LOCKING IS OPERATED, CAN YOU HEAR THE MECHANISM IN THE DOOR WORKING? IN NOT YOU WILL HAVE TO REMOVE THE DOOR CARD AND CHECK THE CONECTOR TO THE SOLENOID/PLUNGER.
Jan 26, 2010 | 1993 Lexus Es 300
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
How do gain access to the spring reces door that stops the ice from comin out.It is stuck in the up position
The control board on the freezer door , pops off from the bottom . May have to use a small screwdriver , prying outward , from the bottom . Remove the 3 plugs from the board . Remove the 4 screws , holdint the dispensor cover and slide the cover out . In the top right , in the dispensor area , you will see a solenoid with a plunger , which the door flap hooks into . 3 screws hold the solenoid on . Usually , rust inhibits the movement of the plunger , inside the solenoid . Replace the solenoid and plunger ( they come togather ) as cleaning will not solve the problem . Pt # WR62X10055 is the part(s) you need .
Oct 03, 2009 | GE Refrigerators
Tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Sep 13, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
The viper is going in circles and will only clean the area around the drain. The reverse valve appears to be partially stuck in the open position.
I had a similiar problem. I took the sweep motor apart and used a scotch brite pad and smooted the inside of the piston that operates the spinout. I also lubed the o-ring seals with some vaseline before putting it back together. I also used the scotch brite pad on the little plastic part and its mating surface the piston operates.
Jul 12, 2009 | Hayward Viper Pool Cleaner
Key gets stuck
There is a solenoid & plunger next to the ignition switch inside the steering column that stops functioning. The plunger must be retracted in order for the switch to turn all the way so the key can be removed. manually inserted the plunger and take out the key.
Nov 03, 2008 | 1997 Pontiac Grand Am
Asko WM33
hi if the timer is on off/finished cycle and door wo'nt open? it may well be the micro switch that is stuck this is the time delay that prevents you from opening door till light goes off ?? it is not uncommon and part is obtainable if you wish diy? by removal of rear panel then the top panel to gain access to door latch/lock attached to inside of front panel you could try tripping plunger back to release door lock first then replace this switch just for info i have removed and found the switch plunger stuck with grit/grease and cleaned it with electical cleaning spray then refitted and prob rectified but your choice ?? hope this helps
Oct 22, 2008 | Washing Machines
ProPlumber 3/4-in Female Brass Yard Hydrant Valve PPYH-3 Logo
584 people viewed this question
Top ProPlumber Garden Experts
Dennis Key
Dennis Key
john h
Are you a ProPlumber Garden Expert? Answer questions, earn points and help others
