Question about Miscellaneous
Hi to all. I have a 9 shot H&R hand gun
When I go to eject the spent shells the sylinder goes up to hi. I thought it was the swing out arm so I ordered one yes it was the wrongs one. So before I send it back I was just wondering what ealse it might be? Thanks. RON I
  • 1,443 Answers
Sounds like the spring is worn out, you need to take to a gunsmith to have repaired.
Posted on Nov 23, 2015
3 Suggested Answers
  • 117 Answers
SOURCE: The Bolt will not stay back after last shell is fired from mag.
Try putting the original magazine back in.The tapco mag probably does not have the vertical extension that holds the bolt open.Compare the two mags side by side.Good Luck
Posted on Apr 08, 2009
  • 59 Answers
SOURCE: How can i find out what length of a shells are ok to use in my Harrington & Richardson arms co. Worcester Mass. U.S.A single shot 410 ga. shot gun
It should be stamped on the barrel. If not, please take it to a gunsmith. He should be able to tell you what lenght of shell can be safely fired from the gun.
Posted on Nov 09, 2014
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
Oct 23, 2016 | Winchester Optics
What does 9mm P.A.K. Blank Gun Ammo stand for
German Abbreviation. "Pistole Automatik Knoll" automatic blank gun [ammunition].
Calibre bore of 9mm and firing "Noise" cartridges usually employed through gas rejection shuttles or replica automatic pistols with a realistic firing simulation where the gas from the shot cartridge is used on the Newtonian principal of opposite forces to eject the spent shell while reloading a fresh cartridge (also cocking the mechanism) ready for the next pull of the trigger.
Learning is fun !
Aug 08, 2016 | Optics
Will it shoot 3 in and 2 3/4 bullets
The gun should be clearly marked on the barrel if it is capable of running 3" shells.
Example:
Jan 29, 2016 | Optics
Nov 09, 2014 | Optics
My Remington 1187 super mag will not eject shells once it has been shot have to play with it to manually eject them
Are you using light loads? Is the gun dirty? Too light a target load may be the issue. Also if you've shot many rounds through it, theweapon may need to be disassembled and cleaned to include the gas ports.
Sep 09, 2013 | Computers & Internet
After 1st is fired it seems to not eject the empty casing or next round misfires. Several times it will misfire. I'm using Federal Long Rifle, High Velocity, 36 Grain Hollow Points. My email address is...
First, listing a gun problem in the Toys section is kinda confusing. 36 grain, so i assume .22 caliber. Is this by chance a P22 or P99?
Next: ejecting vs extracting. Extracting is the act of the spent brass being pulled from the chamber as the slide moves backwards. Ejecting is when the spent casing is thrown from the gun, leaving a clear path for the next round to slide into the chamber.
The most common problems with .22 pistols is that they are dirty. Hands down, and I know this from working at a range. Strip that gun down, and clean the hell out of it. If you're not comfortable, have a gunsmith do it for you. Next, check for burrs (rough edges of metal) on the extractor. Also check for burrs or rough spots on the feeding ramp into the chamber.
If everything looks good, try different ammo. I've seen all different types of ammo fired through different weapons systems, some worked and some didn't. Wolf ammo hates American rifles, its just true. .22 LR is cheap, buy a few boxes of different brands, and see what your weapon likes to fire.
If this is still giving you problems, let me know, and i'll walk you through it step by step
Mar 29, 2011 | Walthers Toys
I have a ithaca model 49 lever action single shot and it wont eject shells after firing it but it will eject it if i dont fire it,in other words it will eject a live round but not a spent one
there is a lever under the barrel and it is probably worn beyond function or broken off all you need to do is disassemble the gun and replace it. ( get yourself some good brass punches)
Feb 08, 2010 | Guillemot Hercules Dualpix HD 4780428...
Slide arm does not go completely forward
My Friend,
It seems you really have outdone yourself! The only thing I can recommend is to go to your local gunsmith ( a gun store could help in the location of one hint, hint) and have them disassemble the old gal. they will assess the damages done by your rookie mistake, and hopefully it's not too bad eh (she's a beauty she is). next time I STRONGLY recommend you take every precaution necessary to not damage you the guns or others. I STRONGLY recommend cleanings after every use, and please be sure to slide the slide arm all the way forward next time. You are lucky you were not hurt.
In my opinion though you may have broken a crucial spring, lock the slide gate shut, and/or dislocated the base of the spring. the shell not fitting I would say is a barrel issue with unburnt black powder, or a small dent in the barrel form the slide mechanism. BUT I HIGHLY recommend you do not try to repair this in your home or take my diagnosis as I have not seen the gun, nor am I a professional gunsmith.
Best Wishes,
KidKRYLON
Mar 22, 2009 | Winchester (026196062448) (20 - 60x70 mm)
DOES NOT EJECT SHELLS FULLY ON MODEL 1100
My Dad's 1100 which is 15 yeaers or older will not eject shells when it is shot and I have pulled it apart to clean which seems to be the major issue. I have a schematic for a left handed 1100 but I need one for a right handed to help me assemble the gun after I have cleaned it. Also, the flat spring that runs along the side in the receiver has come out and I understand it should be peened in, any suggestions? Scott Detring
Dec 23, 2008 | Remington Shotgun Mount 12Ga Lh, B Square...
Open Questions:
Miscellaneous Logo
19 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
