Question about Kenmore 27" Electric Double Wall Oven
Having problem with oven not staying to temp. checd voltage 240v at oven 2nd one that was installed. same problem with both
  • Kenmore Master
  • 5,323 Answers
I suggest u check the over temperature sensor. makes intermident heat
Posted on Apr 17, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
There may be a grounding issue or a neutral wire problem
No heat in oven
Check outlet voltage, a 240v circuit breaker can trip halfway and not be visibly tripped when looking at the breaker panel... 120v will operate the oven controls, but will not heat the elements...
Apr 23, 2016 | Ovens
What size mains wire do i need to install my beko oven ?
That depends upon the mains voltage. 2.3KW at 240V = about 9.6A, which would want atleast #16 (AWG) or 30/0.25 (metric) wire. If your mains voltage is higher, you could use smaller wire. If your mains voltage is lower, you'd need larger wire.
Are you SURE your oven only uses 2.3KW? That sounds awfully low to me, barely more than a milkhouse heater.
Aug 04, 2014 | Ovens
I have Moffat E32ms 208V ,but my singal fase 240v. What I can do.
Those voltages are interchangable...you can hook it up with no problems...
heatman101
Aug 18, 2010 | Moffat E32 Full Size Electric Convection...
Bake at low temp. Heating element vs control board
you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
Feb 17, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Top oven will not heat all the controls are active, bottom oven works fine.
check voltage to element. should be 240v. if voltage is good then replace element.
Jun 21, 2009 | GE JKP27 Electric Double Oven
Oven still wont heat up,after replacing thermostat,element checks
Check voltage at element while on. (dangerous) Make sure you have 240V across the two terminals of element. If not, then the control is the only thing left. Sound like the control has dropped one leg of power. Make sure you have 240 at the plug before removing rear panel.
Mar 17, 2009 | Ovens
Hobart HEC40 208V to a 240V source
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
Mar 08, 2008 | Hobart HEC501-208V Electric Single Oven
OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Nov 24, 2007 | Ovens
Kenmore 27" Electric Double Wall Oven Logo
88 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
