Question about Chef's Choice Kitchen Appliances - Others
The waffles keep sticking to the waffle maker.
I have had it for several years. I used oil on it, as directed, the first time. It was fine until recently. I tried to add more oil to it, but it got gummy and sticky.
  • Chef's Choice Master
  • 494 Answers
It sounds like you've reached the point where you will have to thoroughly clean it and start fresh with the oil process. Oil can only be reheated so many times before it gets broken down and gummy.
Posted on Jun 16, 2015
  • 87 Answers
SOURCE: waffle stickes
The question is! Was this waffle maker brought into the home new or used?
Posted on Jul 16, 2008
SOURCE: Waffles stick in unit
If you add a 1/4 cup of melted butter or margarine to the waffle mix, they do not stick, mine don't stick at all. There is also a recipe using yeast, butter, etc, that makes excellent waffles, and they do not stick.
Posted on Aug 10, 2008
  • 83 Answers
SOURCE: waffle mix spilled over entire waffle maker, inside and out
If it is a non-stick surface brushing cold water on with a pastry brush while it is still ver hot and immediately after removing the food will clean the surface easily. As for the outside, if it is a painted surface a non- abrasive cloth with warm water could possible clean it. I would not recommend pulling it apart.
Posted on Sep 25, 2008
jerryirwin75
  • 18 Answers
SOURCE: Waffles sticking and separating
try washing the inside of the waffle maker with a damp rag then dry..
Posted on Jan 15, 2009
SOURCE: Why are my waffles sticking to my Philips KB5590
WE HAD AN IDENTICAL PROBLEM. WE WASHED BOTH IRON SURFACES WELL AND THEN APPLIED A LIGHT COATING OF NON-STICK SPRAY. PROBLEM GONE - REPEAT AS NECESSARY AND HAPPY WAFFLING !!!
Posted on Apr 17, 2010
How to use the waffler by toastmaster model# 2810R026
Directions
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
Apr 16, 2014 | Toastmaster Kitchen Appliances - Others
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
ProLine waffle maker sticking. Followed all direction from factory. No Pam used.
The plates on the waffle maker need to have some sort of cooking oil or butter to lubricate and prevent your waffle mix from sticking.
Spray some PAM on the plates once the correct temperature has been reached, or alternatively brush on a little melted butter or vegetable oil. Pour in your waffle mix and when cooked the waffle should lift straight off.
Jan 16, 2011 | KitchenAid Pro Line¿ Waffle Baker
How to clean the stove top waffler & keep waffles from sticking?
Best wasy to keep waffles from sticking is to spray the maker with a non stick food spray like "PAM". The other way is to increase the amount of oil in the batter, but that can affect the finished look.
Jan 10, 2011 | Nordic Ware 15040 Belgian Waffle Maker
Why does my waffles stick?
You have to lightly coat the waffle iron with vegetable oil, and then you won't have them sticking.
Otherwise, it's a mess!
Dec 12, 2010 | Toastmaster TMWB2BELW Waffle Maker
Waffles sticks to waffle maker. No matter if i
I notice that this was happening to my waffle maker. I had to remove a thick layer of charred and gummy varnish. This is what the corn oil spray (and maybe sugars) had turned into. No more spray for me.
Now I do not leave the waffle iron hot and empty for long; this alters the oil coating into varnish. Power off until needed for sure.
I apply a thin coating of vegetable (soybean) oil just before adding the first cup of batter. Usually I can get all I need from the cup that measured the oil for the batter! I scrub it around with a boar's hair pastry brush. (Synthetics will melt!) That's usually all I need for a batch of waffles. If they start to stick to one half or the other, I reapply some oil with the brush.
Apr 19, 2010 | Waring WMK300 Professional Belgian Waffle...
We have a new waffle iron and it was seasoned as directed but the waffles stick.
We always use a bit of that Spray on butter... You still need to lubricate it each time you lay in a waffle...
Mar 10, 2010 | Waring WMK300 Professional Belgian Waffle...
Waffle Iron Sticking...HELP
Try using 2 Tablespoons of oil in your recipe.
Mar 21, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
422 people viewed this question
Top Chef's Choice Kitchen Appliances - Others Experts
Tom Chichester
AJMAL KHAN
Christopher Ginn
Christopher Ginn
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
