Question about Sony VRD-MC5 DVD Recorder
When hooked to a vcr with colored cables, when i press record, it says inconsistent color system, check color system.
    New Friend:
  • 88 Answers
Hi . I would suggest trying to connect with a scart lead if you have scart connections . Or even If it is a new model HDMI .
Posted on May 13, 2015
I cannot record a TV show on my DVD-VCR375, niether to a VCR tape or DVD disc. Nothing but static results. The recording mode of my machine works OK in dubbing from tape to disc.
You have to be sure you are running your video source THROUGH your VCR. Just because it's on the TV doesn't mean your VCR can see it. How are you hooked up? Cable? Satellite? If you are on basic cable you have a tough problem. This VCR does not have a tuner built into it. You will have to use a television or other device that has a tuner and a "MONITOR OUT" or "VIDEO OUT" plug in the back of it. This is usually a composite, or yellow-colored cable. You will run this cable into the yellow plug in the back of the VCR that says "IN." You also need "AUDIO OUT" jacks from your television or other device. These are usually red and white cables. Plug these cables into the red and white "IN" plugs on your VCR by the yellow one. If you are using something like satellite where you have a box, you will want to plug in your satellite receiver to your VCR using the same colored cables. If you have to plug in the cables that once went to your television, you need to turn your television to the input you normally use to watch your VCR. You may need to change inputs on the VCR. You should then see your satellite or cable box on the television set. It is now running THROUGH your VCR. Hopefully, at this point, you are hooked up correctly. If you are using the "MONITOR OUT" method, you just have to have faith that it's working. If you're using the other method you can actually see it on the screen. Now tune to whatever you're trying to record and press the record button. Be advised, however, that many DVD/VCR recorders have protection detection built into them (particularly on the DVD side) and your recording may stop part-way through and tell you that "this content is protected." If you have other questions post back. Best of luck.
Apr 24, 2011 | Video Game Consoles & Games
Do I need a special cord to record from digital tv
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
Oct 02, 2010 | TruTech TT1620 DVD Recorder
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Isignia DVD RW suddenly lost color. I now only see B&W
I think u are using the component out to view, right.
First of all see whether u can see a yellow color RCA jack labeled video out.
Try using tht output and post back
Nov 18, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
noavatar_s.png jdrrwoods
Rank:wizard_s.gif Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca1.gif cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Sony VRD-MC5 DVD Recorder Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
