Question about MSI K9N6SGM-V Motherboard
Where can I can find the thermal fuse polymer PTCs on my board?
Seemed one of the PTCs on my board had been blown. I would be pleased if sombody can tell me their locations on the motherboard.
  • Khader Abedalhalim
    Khader Abedalhalim Apr 16, 2015
    Thx, i find them there are 3 GRN fuses on the board..
    I find wich one exactly burned by simply sensing them with my finger one of them was so hot, i just short it & the board start playing agian..
  • 1,602 Answers
Where is the fusible link for my LG dishwasher?
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Sep 07, 2014 | LG LDS4821ST Stainless Steel 24 in....
Tip
Appliance Repair Boise - Whirlpool Duet Dryer clicks but doesn't work.
If your Whirlpool Duet Dryer makes a clicking sound then nothing happens, you most likely have a blown thermal fuse or the control board is bad. It is possible the lid switch is bad but I haven't seen this yet.
Please be aware that sometimes a blown thermal fuse indicates a overheat condition most likely caused by a restricted or blocked vent. Get your vents cleaned every 3-4 years. Lint buildup wreaks havoc with dryers and keeps me in business.
Rich
on Oct 12, 2010 | Washing Machines
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
Microwave stopped working. No power
please follow this steps and fix it. God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_4_57_51_pm.gif
Jan 24, 2013 | Panasonic NN-S541 Microwave Oven
Goodmans st101ss microwave no power
Line Fuse
Main Control Board
Thermal Fuse
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_5_05_57_pm.gif1_24_2013_5_07_19_pm.gif
Jan 24, 2013 | Tappan TMT157E1 Microwave Oven
Why thermal fuse is blown
If you have no power to your machine and the power is on it is the thermal fuse. If the fuse is blown you will get no power at all. To my understanding after talking to many people the thermal fuse is likely the first thing to go bad on a whirlpool dishwasher. A power surge to your unit would cause the fuse to blow or the control board to go bad.
Jan 13, 2013 | Whirlpool 24 in. DU1100XTPS Built-in...
My 2006 kenmore elite dryer wont turn on
The F40 code indicates a communication problem between the main machine control and the blower motor control board. According to your symptoms, it is likely that this problem is being caused by a blown thermal fuse. I recommend the thermal fuse for continuity.
Unplug the dryer before accessing this component. Access this fuse and pull one wire off. Measure the resistance across the leads of the fuse using a volt/ohm meter. You should measure near zero ohms of resistance (continuity) if the fuse is good. If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.
NOTE: If the thermal fuse is blown, check for a restriction in the exhaust vent to the outside of your home. This type of problem will cause the fuse to blow.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3390719.
This should fix your dryer problem.
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Timer on Airconditioner works, however, nothing else works. It has electricity, but will not turn on - just the timer.
the fuse is located on the main board of the ac.fot that the ac upper unit has to be opened.its like a mini tube light.and about 1 inch in lenght .and made of thin glass.
as per my knowledge it can be possible that fuse is blown out,but also possible that the main board it self has a short circuit in the components located on it.because if the fuse is blown out ,then even the timer will not start.but you mentioned that timer is working.still you check the fuse if its proper then its a main boaRD FAULT.mostly it will be a reparing /soldering job.the cost will be negligible.if you are not familiar with soldering a lovcal electronics repair tech is more then enough.
please do rate the solution.thank you for using fixya.keep updated.thanks.
May 03, 2009 | NewAir AC-12000E Portable Air Conditioner
Electric dryer wont start
Just replace the thermal fuse for now. You have gotten good use from this machine. But, this is also may be the beginning of the end. Thermal fuses are not expensive either. These things just go out at no uncertain times.
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
MSI K9N6SGM-V Motherboard Logo
81 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
