Question about Philips Televison & Video
I have a Philips tv model 32pack4507. It was working but I can't get it back on either manually or with a remote. Do I need part or new tv
    Top Expert:
  • Philips Master
  • 75,599 Answers
Try a hard reset to this TV and check. If it do not help you, contact the authorized service center for Philips. Please do not make any experiments to this set; because, it is PHILIPS.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 15, 2015
  • Philips Master
  • 2,992 Answers
Check batteries in remote. Or possibly a new universal remote. I just purchaced a RCA universal remote. Works better than the original factory remote, and easy to program to the correct code.
CowboysFanZ
  • 99 Answers
SOURCE: philips remote control pm435s user manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm435-manual.zip&area=other
Here is the Code and Manual for that remote. Thanks //D
Posted on Apr 27, 2008
aprmaejun
  • 97 Answers
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 22, 2008
SOURCE: Help with comcast remote code setup for philips tv
Try adding 1 to the front of the code. 10054 worked for me. Hope this helps.
Posted on Nov 26, 2008
SOURCE: philips universal remote #cl035a need rca tv, dir tv sat codes
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
I hope that this link helps you!!!.. Your Welcome.. I had the same issue.. tried this and hey! it worked.
Posted on Aug 13, 2009
Puppet03
  • 172 Answers
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Posted on Oct 24, 2009
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
Please tell me what code I need to use with the philips universal for a sylvania TV
There are several models of the remote, and several models of Sylvania TVs. We need more details, like model numbers, to help you. Also, there may be several codes to get it to work. Your manual may have the codes in the back, too.
Mar 01, 2011 | Philips PMDVD6 Remote Control
I need a new remote for a 20ms3442tv
Hello
You just buy one Philips Universal Remote control Model [CL 034] for your Philips Magnavox TV. Both Philips and Maganvox are listed in it manual. OK.
Jan 01, 2011 | Philips Magnavox 20MS3442 20" TV
Need program advice for philips direct tv 2585/01 remote
Oct 24, 2009 | Philips Televison & Video
I have a remote contorl universal philips .i'm tring to makc my citezen tv work lost instruction manual serial numb 50804225
You don't need the serial number, yo need to look for the model. Once you have it, here are most of the manuals for Philips remotes.
Aug 24, 2009 | Philips Prestigo SRU8008 - Universal...
Philips universal remote
You will need to know the model number of your JVC TV. usually located on the back of the TV on a sticker. try going to the JVC customer support website and search for the model number and bringing up the manual.
Dec 21, 2008 | Philips Magnavox Learning Universal Remote
Need code for philips tv
you can get the codes from the link i have given you. Download the file and it has the codes and user manual for you there are quite a few for philips... so be patient and you will get it:)
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/ge/rm24912-manual.zip&area=other
A "fixya" rating would be great for my time to get this info for you.
thanx
Jan 13, 2008 | GE JASRM24912 Remote Control
Televison & Video Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
