Question about JVC Televison & Video
My Jvc tv sometimes switches off itself and when put on dosent respond to remote and even manual buttons won't b working
SOURCE: tv switches itself on and off no picture
Just had this happen to me. It's caused by a failure of the power supply board. Replacing the power supply should fix this issue.
This appears to be a very comon problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy.
Posted on Apr 06, 2009
Obertelli
  • 3006 Answers
SOURCE: tv works fine for few minutes, then the tv wont respond to remote
There's clearly a heat-stressed component in there, possibly something as simple as a badly soldered joint in which a gap opens up due to heat expansion.
It's not that old a TV so may be covered under warranty. If not it's going to need to go into a repair centre where they can find the fault and repair or replace the affected part.
Re-soldering a bad joint isn't always possible in which case the circuit board which it's located on gets replaced instead.
Posted on Jul 01, 2009
  • 458 Answers
SOURCE: pressed 'D/A' button on remote and tv and tv has stopped working
This is the Digital/Analogue input choice. The TV has probably locked up due to a signal failure, try switching the TV off from the mains electical plug, leaving it for 30 seconds, then plug the TV back into the mains socket & try switching it back on.
Posted on Jul 08, 2009
BoiseLCD
  • 63 Answers
SOURCE: Its a tiny 42
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Posted on Oct 08, 2009
SOURCE: tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
Posted on Oct 14, 2011
How do I fix my new TV which will sometimes lock up and will not respond to some buttons on the remote or the TV itself?
it is under 1 year warranty from the manufacturer,contact them for repair,they will send someone to you
May 24, 2015 | Televison & Video
Tv dosent respond to remote when powered by inverter
Inverter is square wave. Square wave interferes with digital circuits sometimes.
Jan 18, 2014 | Televison & Video
Manual for a JVC AV-48PRO Tv and JVC RM-C265 remote
i have a problem with my TV JVC AV-48PRO its not switching on red and green light blinks and not responding to my remote
Jan 17, 2013 | Televison & Video
Menu button stopped responding
If only one button does not work at all or all do not work the unit may have a lock out feature that would be explained in the owners manual.
Apr 10, 2012 | Vizio Televison & Video
Tv is stuck on Video 1 and the remote is missing.Won't respond to the cable remote except on and off. HELP
Try pressing tv first on your cable remote then the video/source/input button on the cable remote. If there is no button on the television itself to switch video inputs a temporary fix for now is to connect the cable box to the video 1 female parts on your television. Buy the cables to do that if you don't have a spare set lying around. You can purchase a remote for your television with the model number from http://www.replacementremotes.com or even a Sanyo remote from a thrift store should be able to allow you to switch inputs.
Aug 21, 2011 | Sanyo Televison & Video
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
Jun 14, 2010 | JVC RM-C18G-1H Remote Control
The remote just magically stopped working, even after new battery
Have you tried pressing the 'input' button again this time to switch from video to tv? This happens in quite a few cases where 1 remote is used for many products. Please try and let me know.
Aug 21, 2009 | Televison & Video
TV shuts itself off. ON/OFF switch no longer works.
If your sure the switch is broken, you can remove the switch and directly attach the wires and plug and unplug to turn it off and on. But it sound like that if the switch is broken you have a slight connection and with an ajar it will turn off and on by itself. The good thing to do would be to purchase a push button switch at your local electronics store for between $1.25 to $10.00 depending on what one you would like to have.
if it is remote control you could have what they call a sliver on the circut board to that can cause this to make the tv turn off and on. Best way to check this is to take the remote batteries out and see if the tv still turns off and on. If so replace the switch.
May 07, 2009 | JVC Televison & Video
Tv switches itself on and off no picture
Cr1spy.
Mar 25, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Televison & Video Logo
41 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
