Question about Hisense SmartTV Wireless Connect HiMedia
YouTube won't work all of a sudden. It says it isn't compatible with my device. I tried a factory reset and upgraded the device. I also unplugged the tv and the wifi for several minutes. any ideas?
Model Number 32k366w
Virgin ZTE camera stopped working suddenly. Why?
I would first start with backing up your data and then resetting to factory defaults. If that fails to work I would then check for a firmware upgrade from the manufacturer or provider. If that fails then I would send it in for warranty work, or start looking for a replacement device.
Dec 03, 2014 | Cell Phones
Ematic hard reset
Upgrade to a better android operating system YouTube can direct you in most cases but it's a precise and complicated process. Try YouTube search "android upgrade for 'device model'" be sure when messing with this stuff you have the right info. One mistake and you may have a paper weight. You may have to root your device prior to upgrading from the manufacturers operating system but can unleash a whole new tablet with a good version of Android. Do the research. YouTube can help.
Dec 05, 2013 | Audio Players & Recorders
I have a 37LG505H-UB LG LCD TV and when I watch it, it all of a sudden starts scanning for channels on the RF input even though I have it hooked to HDMI on the STB. It won't stop and when I turn it of
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 03, 2017 | LG Televison & Video
When I get on the internet it says "Insuffiecient
Here are the general instructions. Select Menu, then in the menu selsct "Web", in the next menu select "Browser Settings", then in the next menu select:
CLEAR CACHE
DELETE COOKIES
DELETE HISTORY.
If you continue to get a memory error your phone may need repair.
Oct 12, 2011 | Motorola Mobility Clutch i465 Cell Phone
My Philips GoGear SA011 device won't activate. It just flashes the word "PHILIPS" then it just stays like that.
connect the same to usb cable and upgrade the firmware, remove the battery and try reset ing the power switch and re instal battry and format and restore factory settings
Jul 14, 2011 | Audio Players & Recorders
Hi there, I have a SamsungGT-B7330.Suddenly, I
Sounds like a defective sound card, I would try to restart again and then perform a factory reset on your phone.
To perform a factory reset its usually inside the phones settings, make sure to backup your contact info and any other information you would like to save.
worst case scenario take your device into the dealer, they will perform a factory reset and if the device continues to be broken will likely replace the phone.
Good Luck!
Jun 17, 2011 | Samsung Cell Phones
All of the sudden the remote control does nothing, won't work at all. What can I do?
try to remove the batteries from remote, if that don't work, unplug main unit from wall for 40 Min., and it will reset back to normal.
Jun 09, 2011 | Bose Audio Players & Recorders
No sync no signal
Tries tv and those pay boxes unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Those pay boxes,now will be rebooting and upgrading it softwares.The incomming broadcasting signal sync problems should be solved,if still have no sync signal flashing,than 90-95% those pay boxes have a problems.Call ur cables providers exchange the reciever box.
Mar 01, 2011 | Hitachi P50H401 50 in. Plasma HDTV
O2 PDA is not working after Upgrading the software
I would say that either the upgrade package is not compatable with your device and has not installed anything beyond flashing/deleting the current installed eeprom info (no info on the eeprom at all) or the device has been restarted or uplugged during the flash eeprom stage, the factory/master reset should take you back to config mode at least, when trying the master reset the power should be on, then activate the master reset with a paperclip or pin only will work, press and hold until the red light goes out, remove the pin or paperclip activator and your device should power up as normal with the old eeprom info or ready for new eeprom info to flashed onto it if you are successful here ensure you use the istall package that came with this device Should be WinMobile/II or IIe I think.
May 17, 2007 | O2 Xda II mini
Hisense SmartTV Wireless Connect HiMedia Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
