Question about GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator
I have some frost on back wall and some food freezes now and then.
The water is off to icemaker should i turn it off till ifix that.
    Habit-Forming:
  • 41 Answers
Check to make sure the drain is not plugged
Posted on Apr 14, 2015
  • GE Master
  • 2,963 Answers
Assumeing you are saying frost on the back wall of the refigirator, I would increase the temperature for the refrigirator area. If that does not help you may have problems with the defrost system.
Testimonial: "there if frost in the shelf slots towards the top also. ive raised temp to 46 to see if that will do anything. wondered if drain was frozen behind panel"
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ge profile PSS26MGP side by side installed in Oct 2008. Background: on 1-03-2011 freeze-refer temps approx 13 and 48, apples in top deli-fresh drawer were frozen. Ice maker not making ice, minimal water...
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a Side x Side style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem. System problems may be a leak in the refrigeration tubing,or an inefficient not 100% pumping compressor.
Feb 07, 2011 | Refrigerators
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Ice box
In the LG side by sides they have developed a new ice cup tray. The tray has a little wall so that the water stays in the tray and doesn't go onto all of the ice causes it to stick together.
part number is 3390JA1150A
Sgt 48
Feb 08, 2008 | LG LRSC26920TT Side by Side Refrigerator
GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator Logo
64 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
