Question about Konica Minolta Bizhub 8031 Copier
When scanning document message comes up "Job done improperly, Check record" What does that mean?
  • Konica Minolta Master
  • 6,161 Answers
Should be able to select the job then check job details which should show you what happened
Posted on May 26, 2015
Kevin Hayes
  • 167 Answers
SOURCE: transfer error with large documents
If it was a memory error the copier would indicated this.
It may be due to bad line connection or limitations of the server, but if you are getting a log error, it is most likely a bad connection to the internet.
Posted on Jul 02, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Posted on Oct 20, 2008
SOURCE: Scan job returns error job is done improperly. Check log 6385
I had this problem when sending to mail account.
This can also be changed for ftp/smb.
So maby this is the answer to you problem.
Solution: Extend the time-out from 90 to 300 seconds
Goto the setting of the machine (http://<ip>) and login with Administrator account.
On the page Network click on Email/SMTP.
Change the Time-Out setting to 300 seconds.
Good Luck!
Greets,
Ivan
Posted on Mar 18, 2009
DocuSystems
  • 10 Answers
SOURCE: job has been done improperly check log files
The first thing to try is to restart the Bizhub. Power switch for that is located behind the front panel where the toner cartidges are. Not the switch to the side of the operation panel.
If that doesn't work, you need to check the job history. Press details, there will be a description of the error.
Server Connect Error: The Bizhub cannot find your computer.
Things to check:
Firewall, ports that need to be open are TCP 139, 445, UDP 137, 138
Netbois resolution not working, try using your PC's IP address instead.
If using Host Name to resolve, try Host name in uppercase.
Folder Not Found:
Check to make sure you are using the correct share name. Not necessarily would be sd.
Login error:
Need to use a Username/Password which is an active account which has priveledge for the shared directory. If on a domain, use a domain authentication string for the username (username@domain.com) If on a workgroup, \\COMPUTERNAME\Username If your password rotates every 60-90 days, could be that all you need to do is update the Bizhub with that information.
Posted on Aug 05, 2009
  • 214 Answers
SOURCE: Job has been done impropely. Check the log
you have to check the settings, check that everybody can read/write to the folder you share, be sure to give the right path to the directory forr printer. maybe you have to use name and pwd
Posted on Oct 15, 2009
When we go to scan documents to the a network station address only three pages will go through the scanner and we then get a message telling us that the job has been done improperly. What's the sitch?
1.from the pagescope web connection enter admin mode
2.select network, email,email transmission.
3.enter an admin email address it does not have to be a valid address i usualy enter in this fashion scan@nameofyourcompany.com
4.enter a device email address in the same fashion as above.
5 select apply.
the device email address and admin email address have to be entered in the copier or you will get this message
Nov 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Sep 25, 2009 | Konica Minolta bizhub C250 All-In-One...
Job has been done improperly check log files
Things to check:
Folder Not Found:
Login error:
Jul 30, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
May 14, 2009 | Konica Minolta Office Equipment & Supplies
Good Luck!
Greets,
Ivan
Jan 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Transfer error with large documents
I'll have to call tech support on this one but I have a feeling that the job is too big for the copier to convert into a pdf file and send it out. It could be cause by lack of printer memory to handle the job. If the copier is hooked up to a fiery controller, then it would work because it has enough hard drive space to process it. You could try changing the format from pdf to another file format and see if that works or break the run up into two jobs.
Jul 02, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Trying to use photo copierfrom the touch pad
eee, what version machine you have ?
C252 is copier
C252p is a printer version without copy function
what are you trying to to? copy ? scan ? print ? fax ?
Nov 29, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub 8031 Copier Logo
65 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
