Question about Refrigerators
How do i fix ice maker
Ice maker worked great for 8 years then started working only intermittently and now no water goes lot ice maker but does go to water dispenser
  • Refrigerators Master
  • 473 Answers
Could be 2 different problems. Inlet water valve is a dual valve (2 halves). 1 half feeds water to the door dispenser, the other half fills the icemaker. The icemaker half could be bad or blocked up with sediment causing a no fill situation. 2nd problem could be the icemaker itself which sends power to the inlet valve when it needs filled. Usually the inlet valve fails first but you need to test and see.
Posted on Apr 16, 2015
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
Ice maker suddenly stopped working. It makes strange noises intermittently, sometimes sounding like a Geiger counter. It no longer draws water. What can I do to diagnose & fix the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 10, 2010 | Refrigerators
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
I have a Whirlpook refrigerator, about 6 - 8 years
Try a quick fix by useing a blow dryer to thaw around the water tube and ice maker. Also for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 13, 2010 | Freezers
Intermittantly no water from inside water dispenser
I just started having the problem of no water dispensing from the in-door dispenser. I checked the operating manual and it suggested that the refridge temp may be set too low thus freezing up the water line. I have set the temp higher and we will see if that helps. I do not think that will do it because as you too note, the ice maker works fine. If the filter were an issue the ice maker would not refill either.
illinoisjas
Apr 19, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Has anyone successfully fixed his or her water dispenser?
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Feb 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
