Question about Blu Cell Phones
How do i unlock my blu dash jr 2.0 .nothing is working?
D139, yhlbludashjr,null,vol+and power button,email,factory reset data almost every thing.
4 Suggested Answers
SOURCE: Unlocking code for Brain Challenge vol.2
me too at ranma_pgr@yahoo.com
Posted on Feb 06, 2011
prashant2012
  • 1127 Answers
SOURCE: I forgot my code to
Hi
Send me the your mobile IMEI no to security code.
Posted on Jul 12, 2011
  • 61 Answers
SOURCE: How to reset blu neo jr
Since you didn't suggest which one you wanted, soft or hard reset, I have included answers for both:
To Soft Reset. First method:
1) Remove and replace the battery.
2) Press the Power Button.
Second method:
1) Press the Power Button until the menu which shows "select option turn off phone" appears or
Third method:
1) Press the Power button until the phone turns off, then press it again until it turns back on.
There are a couple of methods to hard reset your Blu Neo phone back to default factory settings.
1) Depress the power button until the unit is on.
2) Browse to Menu > Settings > Privacy > Factory Data Reset > Reset Phone.
The resets your phone to out of the box settings. Only to be used if you wish to return the phone back to the condition it was in when you first purchased it.
The second is to:
1) Turn you phone off.
2) Hold the Volume Down and Menu and Power buttons [all three at the same time]. Hold all three fingers down on those buttons until you see the Recovery Menu [it may take a few moments], then release your fingers from the three buttons listed above.
3) Select "Wipe Data/Factory Reset" using the volume buttons to navigate between the choices. The use the Power Button to select the choice.
4) Confirm "Yes - Delete All User Data"
Either of these two methods will reset your Blu to its out of the box configuration. BE SURE you have a back up if you wish to restore your settings.
I hope this helped you.
Posted on Mar 13, 2015
Second method:
Third method:
The second is to:
Mar 13, 2015 | Blu Cell Phones
How do I do a screenshot with my Blu dash jr 2.3.5.
With the dow volume button and power button. push them at the same time.
Jan 14, 2015 | Blu Dash JR D140 Unlocked Black Dual Sim...
How do i reset a blu dash jr 4.0 k phone? model part is D142k
There should be an option to reset your phone in 'settings'.
Back Up and Reset should give you the option to reset with no problems. As you enter this option, the last option here is 'Factory Data Reset'. Try this and let me know what transpired after....
Dec 21, 2014 | Blu Dash Jr 4.0 K Cell Phone
My home screen and reset
Hi, unfortunately its a job for a technician, yr fone has to be connected to a computor to access the security setting. Its a quick job provided you have tornado cables. Take it to yr nearest trusted cellular shop.
Dec 02, 2014 | Kurio Touch 4S Handheld
How do i unlock my blu dash jr 3.5 after too may parten attemps
You may have to do a factory reset. Reply for info!
Oct 12, 2014 | Blu Dash Jr Cell Phone
How to install stock rom on blu dash jr d140?
hardrest sir if will done!!!
check diz one
If You Can't Boot
If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down.
Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
  • Nexus 7: Volume Up + Volume Down + Power
  • Samsung Galaxy S3: Volume Up + Home + Power
  • Motorola Droid X: Home + Power
  • Devices With Camera Buttons: Volume Up + Camera
Similar devices will likely use similar key combinations. For example, the Nexus 4 also uses Volume Up + Volume Down + Power.
If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
Press the Volume Up and Volume Down keys to scroll through the options until you seeRecovery mode on the screen.
Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen.
Select wipe data / factory reset with the volume keys and tap the Power button to activate it.
Select Yes - erase all user data with the volume buttons and tap Power. Your device will be reset to its factory state and all your data will be erased.
If your device freezes at any point, hold down the Power button until it restarts.
If You Can Boot
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3.
Tap the Factory data reset option and to through the reset of the steps to confirm the factory reset.
If the factory reset process doesn't fix your problems - or doesn't work at all - it's likely that there's a problem with your device's hardware. If it's still under warranty, you should have it fixed or replaced.
(There's one exception to this: If you've been flashing custom ROMs and messing with your device's low-level software, it's possible that you could have overwritten the stock recovery software. In this case, it's possible that you have a software problem and not a hardware problem.)
goodluck
Jun 22, 2014 | Blu Dash Jr D140 Cell Phone
Will not charge
My grandson forgot his password for his Nextbook Tablet, how can I unlock the screen to rest his password.
Jan 11, 2014 | Nextbook Premium 8 Se Android
Pattern unlock screen
Follow these steps to unlock the screen:
Any info saved on device will be wipe since this is an External Factory Reset
  1. Press Vol+ & Power (Android robot & red exclamation triangle on screen)
  2. Press Vol- & Power & Vol +
  3. Press Vol- to highlight 3rd option, wipe factory data reset & press Power to select
  4. Vol- to highlight Yes-delete all user data
  5. Power to select Reboot Now
Device back to original settings & ready to use.
Jan 09, 2014 | Cell Phones
How do I perform a factory reset on Nabi Jr. Daughter uncertain her info on it??
A factory reset will wipe all data including installed apps. Make sure the battery is fully charged before beginning this as you could "brick" your Nabi. Here's the video I used with the procedure on it: https://www.youtube.com/watch?v=T-bamfAKvgk
Steps are:
  1. turn it off
  2. hold power and vol + button until menu appears
  3. press vol - to highlight "recovery kernel"
  4. press vol + to select it
  5. press vol - and vol + at the same time
  6. menu will appear use vol - to select "wipe data factory reset"
  7. press power button to select it
  8. press vol - to select "yes delete all user data"
  9. press power button to select it
  10. this will perform a few actions and take you back to the menu from step 6 should already be on "reboot system now"
  11. press power button to select "reboot system now"
  12. the Nabi will reboot and reset to factory defaults
Dec 26, 2013 | Computers & Internet
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Cell Phones Logo
48 people viewed this question
Top Blu Cell Phones Experts
Lawrence Oravetz
ace87
Level 1 Expert
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
