TV Shuts off intermittently and throws 2 different error codes
I have had issues with this television for awhile now. Here is a detailed report of the issues I am experiencing. For over a year now, the television randomly decides to shut itself off. Most of the time, I simply unplug the TV from the wall and hold down the power button for 30 seconds, this usually gets the TV working for several weeks. However, about 6 months ago the TV began throwing error code 32. When it did this, I removed the lamp and cleaned out the area in the TV for dust (there was A LOT of dust in the area and on the fan) After cleaning, the TV worked for a few months. Since then, the TV would occasionally shut down and throw error 32 again (lamp door open), I would tighten the screw and push down on the lamp door to fix the issue. The issue would still come up occasionally (and then would go away once I tapped on the door). This weekend however, the TV kept constantly shutting off and none of my previous methods would work. I then got a error code 12 for THE FIRST TIME (lack of 12v power, check cables) I reset the TV and got error 32 again. I am waiting for error 12 to come back so I can re-seat all the PCB connections however it is still only producing error 32. Does anyone have any suggestions other than re-seating the PCB connections and checking the switch on the lamp door that produces error 32? I have been dealing with this intermittent issue for over a year now, but the problem always goes away before I get to taking the TV apart.
techman
  • 3130 Answers
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
SOURCE: Shuts Off After @ 60 Seconds
Some of the Mitsu *25's are covered by a factory recall of the optical engine, even if it is out of warranty.
The airflow message is a faulty temperature sensor located near the lamp. Temporary fixes (that will not void your warranty), are as follows:
Find the inlet vent, clean the filter, then place a small fan in front of said filter.
Call a repair company thats an ASC for mitsu, they will replace the sensor (not repair).
Sometimes, when the change lamp message appears, and you try a reset, it does not work. Unfortunately, this is a known problem without a known solution, other than just keep resetting it.
Posted on Dec 06, 2007
SOURCE: No Light from projector (worked previously)
theres prob something wrong wif the bulb
Posted on Dec 20, 2007
SOURCE: RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Posted on Jan 18, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Posted on Feb 13, 2008
Error code 4. Power LED blinks 4 times than shuts down.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 01, 2015 | Televison & Video
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Jun 17, 2015 | Sharp Televison & Video
I have a samsung tv ln32d403e4d that works for awhile then shuts off and red light flashes
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 06, 2014 | Samsung Televison & Video
It just turns its self off
have you tried accessing the self diagnosis feature as soon as it shuts down to see what the blink code is? If so let me know the error code and I will assist you with the issue
Dec 09, 2012 | Mitsubishi WS-65411 65" Rear Projection...
Philips TV model 32PT6441/37b turns on but goes blue screen and shuts off after 2 min. LED flashes 11 times then 1. Turning off the TV fixes it for awhile then it starts up again.
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 03, 2012 | Philips 32PT6441/37 32" TV
When turn tv on, it shuts off and power light
This model uses the power light for an error code.
Count the blinks----3 blinks a pause and 3 blinks is the most common.
If you have to--unplug the set and then plug it back in and try to turn it on----count the blink code and let me know what you find.
I am here to help people.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 22, 2009 | Panasonic PT-47WX42 47" Rear Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Last night my laptop, sony vaio pcg k35, froze up with a message that said "fatal error" Installed new 250 gig hard drive on it. Half way thru the recovery cd the unit just shuts down. Any ideas? Thank...
Check your RAM memory !
Go into the BIOS and note how much memory is reported. Then reboot and repeat that a couple times to see if the amount that is reported changes.
Also, if you can, go to the system screen in the control panel and see how much memory is reported there.
If it is different from what you have installed or if it differs intermittently you may have a soldering issue on the memory bank connectors.
The solder used these days is lead free RHOS compliant and makes poor soldering joints prone to failure after a couple of years.
Apr 04, 2009 | Sony VAIO PCG-K35 Notebook
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Flashing light - TV shuts down
I will need the model number of your set in order to help you, but different models have different meanings for the error code. Your set is flashing an error code. Please respond to this and I will be able to help you with the problem.
Jun 15, 2008 | Sony Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
