Question about Sewing Machines
Threading the machine and what the tension should be set at
  • Sewing Machines Master
  • 2,963 Answers
Usually the owner's manual is quite descriptive. Try MFG website or email their customer service. or try manualslib.com
Posted on Apr 15, 2015
4 Suggested Answers
SOURCE: necchi
Same here but found this, hope it helps you out : )
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_584_586_threading_Diagram.htm
Posted on Dec 26, 2007
talk2ginny
  • 34 Answers
SOURCE: XL tension setting
Hi - and welcome to FixYa. It sound like your machine is not threaded correctly. Here is the first rule: when you thread your machine, make sure your presser foot is raised up. Never thread your machine when your presser foot is down. When the presser foot is raised, the tension dials open and allow your thread to pass through the dials when you thread the machine. If thread is loose and hard to handle while you are trying to thread, just press down on the thread somewhere near to the top of the machine so it does not slide around. Here is the good news - when you have reached the needle, you can lower the presser foot. Before you thread the needle, pull your thread - if you threaded the machine correctly, the thread should not move. If it does move, you need to start over. If the thread does not move, you can thread you need with the foot up or down, pull the thread under your presser foot and pull it toward the back of the machine. Leave a 2 or 3 inch tail.
If you don't have your manual, you can download a free copy from the Brother web site. Brother manuals have very detailed, easy-to-read instructions. To get to the correct web page, use the link below:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl3500t3510eus.html?reg=us&c=ca&lang=en&prod=hf_xl3500t3510eus
If you and other readers have a minute to rate my instructions, it helps me to better understand what folks need when they come to the FixYa site for help.
If you have more questions, or if the link fails, please feel free to comment and I will answer as soon as I can. Good luck, and have fun with your machine!
Posted on Feb 04, 2009
SOURCE: threading machine
here's a free pdf downloadable manual
http://www.singerco.com/uploads/download/445_4830_4832.pdf
also change the needle
Posted on Sep 05, 2012
What else can I try to get the Overlock tensions correct on a Burnett funlock 003? I have re-threaded checked the threading and messed with the tensions to no avail
You haven't provided symptoms of what is happening with your machine, so this is just a general guideline.
Remove all the threads from the machine. ALWAYS RAISE the presser foot when threading. Be sure to thread each thread IN THE ORDER specified--threading out of order will guarantee a problem! When threading the tensions, always give each thread an extra little tug to make sure it is seated completely (with one hand, grasp the thread below the thread tree and the other hand below the tension disk and tug--it may make a "pop" as it seats). Verify that each thread pathway is correct.
Set the tensions to the midway point. This is the standard beginning point for overlock tension adjustment, although some tweaking may be needed because every machine is different.
If the machine is still not performing correctly with some tweaking of the tensions, you may want to take it for service.
Dec 23, 2016 | Sewing Machines
I just got my sewing machine 2 months ago just started to use it icant because it keep breaking the thread ihave a fleeling i have it sat up wrong like the teason als may be t o tight thanks Jan from
***Upper tension setting
*** Put the pressure foot up.
***As you are threading give little tugs to check for snags. Snags must be fixed.
***When finished threading (not the needle) put the pressure foot down.
***Check the tension by starting at zero and increase the tension slowly and give small tugs to see if the tension is rising. (This is all done without the needle being threaded)
***When you feel comfortable this is working then thread the needle and set the tension at four.
***Set the bobbin tension. Attachment gives instructions.
Now that all of the tension has been set you can try for
Sep 30, 2015 | Singer Sewing Machines
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
I just changed my Kenmore serger's needle and it stopped making the overlock stitch. I rethreaded the machine twice and make sure the position of the needles is correct but it didn't help
Hi
If you have the operators manual for this serger, you should be able to follow the threading from the start successfully. Some machines have a better threading diagram on the machine itself.
The needles should have the groove facing the operator's position. They should also be fully inserted in their mounts. Most sergers do not release the thread tensions when the presser foot is raised, therefore, you must zero the tensions to make sure the threads are fully entered into the tensioners when threading anew. After threading, you must readjust your thread tensions to the desired tensions for the set-up you plan to use. Thread tensions should be recorded for each stitch set-up because each serger tends to be a bit different, and therefore, allows you to quickly adjust for the desired stitch needed. The different stitches are adjust and fine tuned by each individual thread tension.
Hope this helps
Ray
Dec 22, 2010 | Kenmore Sewing Machines
How to thread euro pro serger. threads aren'y interlocking
If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
Turn off the power.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
Turn the handwheel so the loopers are at their highest position.
Begin threading from the right to the left - lower looper is usually the first to be threaded.
After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
Mar 23, 2010 | Euro-Pro Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
