HI HI I have a WA80G5 washing machine recently after every wash it is giving a message to check filter irrespective that I had just cleaned it, please suggest what can we do
The machine is only 2 Years old and never gave any issue before
  • Washing Mach... Master
  • 2,963 Answers
It is probably complaining about air movement. The vent hose may be pinched, or its outlet outside the house blocked or a critter found a nice place to sleep or perhaps a sock got into the air stream after the filter somehow. or the "fan" is not working quite right. It might also be a sensor problem that it giving wrong information to the "brain".
Posted on Apr 14, 2015
My washing machine wont start?
What is the complete model number of your unit?
Dec 07, 2012 | Samsung Washing Machines
Explain erroe 4E
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jun 05, 2012 | Samsung WF337AA Front Load Washer
Hi We have a Kenmore HE2 plus front load washer. Its not too old but it came with the house. Recently we have been getting error messages 5D, F21, and F23. I pulled off the front panel and cleaned out...
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Sep 06, 2011 | Kenmore HE2 Plus Front Load Washer
Our lg washing machine has an OE error message what does this mean
Hi dear.OE code related to drain problem.Please checked the filter,open it,clean it & check for any obstacle blocking the pump to do it's function.(Impeller of pump should freely turn.)Please also check drain hose for kink & blockage.Please keep in mind,some times pump seems normal but it can malfuntion & needs to be replaced.If you are not sure,please call service centre.I hope that helps.Thanks.
Nov 12, 2010 | LG Washing Machines
Samsung model WF8602NHS showing error message 4E
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Sep 03, 2010 | Samsung WF306BHW High Efficiency Front...
Samsung washing machine gives Low Water pressure error message and interrupts cycle. Checked inlet filters. Sometimes gives leak/flood warning message. How can I turn off these messages?
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Dec 29, 2009 | Samsung WF448AAP Front Load Washer
My 7kg samsung washer always flashes error code 4E now... please give me the solution...
Jul 04, 2009 | Electrolux EW1200i Front Load Washer /...
Samsung washer
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Inlet tube on washing machine
Jan 21, 2009 | Washing Machines
Open Questions:
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
