Every tike i turn on my panasonic, radio it turns itself off and shows f61. What does this mean and do i fix it
  • Audio Player... Master
  • 2,992 Answers
If you have an Owners manual, it should tell you the error code in the troubleshooting section. No manual? try MFG website, or email their customer service, or try manualslib.com
Posted on Apr 14, 2015
marsrover
  • 682 Answers
SOURCE: Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Posted on Apr 04, 2008
appman67
  • 33 Answers
SOURCE: f61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Posted on Sep 21, 2008
SOURCE: f61 is my problem
This fixed my unit;
remove the top cover and power it up (keep hands and other body parts clear)
check the cooling fans at the right and rear of the unit, are they turning as fast as they should be?
If not remove the fan and peel away the sticker from the center anput a drop or two of WD-40 down the hole and spin the fan until it loosens up then reassemble.
This fixed mine. Hope it fixes yours.
Posted on Nov 18, 2008
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
F61 on panasonic SA-AK220
There are no error codes in the users manual. In this series of models panasonic has standardized error code meanings. F61 means a failure in the power out circuits. Your first option is to remove all your speakers and the associated wiring with the power off. Repower unit and see if error is still there. If not, you have a speaker or wiring problem. If still there, you have an internal failure requiring service.
May 19, 2012 | Panasonic Audio Players & Recorders
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
Oct 16, 2010 | Panasonic SC-AK18 CD Shelf System
Hi ther i have a panasonic sa-nc9 hometheatre system and it is showing the f61 error message
THE F61 ERROR USUALLY MEANS A FAULTY FAN,BUT IT SOMETIMES CAN BE FIX JUST BY GIVING THE FANS A GOOD CLEANING.
Oct 05, 2010 | Panasonic Audio Players & Recorders
F61
That code means the audio amplifier IC´s are dameged and need to be replaced
Jan 23, 2010 | Audio Players & Recorders
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
61 people viewed this question
 Grubhead
Grubhead
