Question about Miscellaneous
I also have a robin weeder shaft I bent can it be straited or what store do I get one at it shakes real bad I lost all my screws to hold on the red top except one where do I buy more and I need a tip
    New Friend:
  • 21 Answers
Hi troy. yes it can be bent back into shape as the shaft is only a outer case for the internal drive shaft and a holder for the bush guides for the shaft.
just bend it a little at a time and keep checking it with something you know that's straight.
GOOD LUCK
Posted on Apr 26, 2015
emissionwiz
  • 80339 Answers
SOURCE: ENGINE SHAKING REAL BAD WHEN IT IDLES
Sounds like you have damaged the engine, you will need to have the engine checked for a blown head gasket, this is not a new engine, but it will be expensive to fix if the gasket is blown, which I suspect it is.
Posted on Nov 07, 2008
Zeevert
  • 373 Answers
SOURCE: 4 wheel drive shakes
This may sound silly, but if you have a true 4WD, make sure all 4 tires are the same size, especially front to rear.
Do you have the vibration at all speeds?
Posted on Dec 18, 2009
johnjnail
  • 1702 Answers
SOURCE: When I go to slow down like at a red light the
you have a bent front brake rotor, we see this allot espically after a panic stop, or after allot of havey rain you can have them refinshed or replaced....good luck
Posted on Aug 06, 2011
SOURCE: what makes it shakes
Sounds like bad brake pulsation, meaning warped rotors. When rotors are warped , they push the caliper piston in and out ,causing the brake pedal to pulsate and shake the steering wheel. I would start with replacing the front pads and rotors, and if you have drum brakes in the rear, have those cleaned and adjusted for a more balanced braking system.
Posted on May 15, 2014
When my pole saw is extended it is shaking really bad runs fine when it's not what could this be ?
I am assuming you have checked all screws are tight. Unfortunately a tiny shake in your hand ince travelled the distance of the saw will turn into a large shake by the time it gets to the end. Make sure your holding it correctly and if all else fails it could be a slightly bent bar which is very dangerous to use.
Feb 26, 2015 | Garden
I have a 2001 Ford F-350 super duty and it shakes real bad when I get up to like 40mph but as soon as I let off the gas it stops. Any ideas
It is probably a combination of several of the following:
1. tires out of balance and/or out of round, cupped, bulging etc
2. bad shocks
3. loose suspension bushings front and/or back
4. bent or out of balance drive shaft
5. bad U joints
6. bad wheel bearings
Feb 06, 2015 | Ford Cars & Trucks
Craftsman mower deck belt tensioner keeps bouncing and shaking the deck
Bad pulley ???? Bent blade shaft,Bad bearing???
May 31, 2014 | Mtd Garden
My car shakes real bad, I have to hold on steering wheel tight
This can arise from a variety of causes
- lost wheel balance weights, throwing this out
- a bent rim from hitting a pothole
- an out of round tire, which can develop over time
- worn or loose wheel hub bearing
- worn or loose suspension joints
- worn or loose steering components eg tie rod end
If unsure how to check these, get along to a suspension and tire shop, as it could be something dangerous to you.
May 15, 2014 | Dodge Neon Cars & Trucks
Car has just started to shake real bad, like all the wheels are loose
Possibly lost one of the balance weights from a tire.... or you have a bad bearing on the drive shaft U joint.
Depends on how fast you are going.....
Jim
Nov 02, 2013 | 2002 Dodge Intrepid
When I go to slow down like at a red light the Sterring wheel shakes real bad...What is the cause?
Aug 06, 2011 | 2005 Chevrolet Equinox
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Shakes real bad
got a steel belt gone in one of the tires? pitmem arm bad? ideler arm bad? drag link bad? tie rod ends bad? wheel bearings bad or loose? bent rim?
Feb 03, 2009 | 1986 Ford Thunderbird
Van shakes while driving
I've had several of these vans with this problem, check the transaxle for low fluid. Each of mine would start shaking when the fluid was low.
Jan 02, 2009 | 1996 Dodge Caravan
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
