Replaced lamp.good sound.no pic.red light flashing.fan not working..
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
It over heated you need a new tv now lol
Posted on Apr 14, 2015
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
SOURCE: Mitsubishi DLP - model #WD62725
fixityrsel is wrong.
1 The "Airflow message"is just a bad connection and very easily solved.Mitsubishi has a service bulletin out and will cover the repair for free. Your set may not even have the defective connectors.
Your set was manufactured in 2004..Call any authorized Mitsubishi
servicer.
Capacitors are very easy to find! Any (105 degree) PC mount 3300uf@ 16VDC will work fine..and not bulge again..Higher Working voltage than the stock 10 VDC is what caused the problem with the caps.
Mouser electronic is one of hundreds of suppliers for those caps
Order online if you know for sure they are bad in your set.
Dan
Posted on Aug 14, 2008
  • 133 Answers
SOURCE: Sony KDS60A200 won't turn on
yes, the 3 blink error code is a defolty fan, you can take the back of the tv off, it will most likelu be the fan that is faceing you on the left side, it is held bu 4 screws, take it out, (1 plug) and blow it off with canned air, or an air compresser, that will buy you a short time, you will need to order a new one on the sony website, sometimes blowing it out wont work, and sometines it will give you around a week
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
  • 68 Answers
SOURCE: flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
Posted on May 19, 2010
Mitsubishi WD-65733 Red light on Replaced lamp twice
I'd just replace my lamp just three days ago and the problem still
exsist
Nov 10, 2013 | Mitsubishi WD-65733 65" HDTV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Htachi Rear Projection Picture/Sound Lost
If you never replaced the lamp it may be time.4 years to run on 1 lamp is a good run.If you were having no other problems I would say it`s safe to say that will solve your problem
Jan 14, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
If my lamp is out, would sound be present?
Check lamp cooling fan for dust blockage. It is located inside the back cover (10 screws) and is in a horizontal position above the lamp from the rear side. This is an air intake fan. The cooling fan you can see on the back panel is the exhaust fan that sucks out the hot air. A clue is hot or melt marks around the lamp housing.
If the lamp cooling fan is blocked you'll get red flashing diagnostics light flashing. It's trying to say clean me so I can keep the new lamp cool. Sony is silent on this in it's manuals. I'm guessing they don't care because is causes lot's of parts business!
I learned all this after replacement lamp burnt out after 1 week. My lamp cooling intake fan was found blocked and wasn't spinning. I saw the exhaust fan working and thought all was ok, not even knowing there were more fans. Some models even have another fan inside the optics blocker. I didn't take mine apart that far.
Nov 23, 2008 | Sony XL-2100U Projector Lamp for...
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Dec 04, 2007 | Sony KDF-E55A20 55 in. LCD Television
Flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
