Question about Sanyo DP50747 50 in. Plasma TV
I have a Sanyo Plasma TV.. On the left side when facing TV front.. Had a three inch blue line from top corner to bottom corner on same side.. TV won't turn on now.
    Top Expert:
  • Sanyo Master
  • 50,314 Answers
  • 92 Answers
SOURCE: philips 42" plasma blue line down left side
the lines are most likely the panel which isnt cheap
the blue speckles are just a voltage adj. on the y sistain if you feel confident enough you could try this yourself(though expensive equipment is usually required i do without). what you would have to do is take off the back panel if you have a stand put it back on that. easier to work on. then plug it. BE CAREFUL not to touch anything inside!!! from the back you will see a board on the left side on that board will be a small board attached vertically it will have a gray screw attached(very small). with the tv on you adj. the screw until the blue goes away(a little does alot).
Posted on Jan 20, 2008
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
SOURCE: LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
http://greenrenovation.wordpress.com/du-42px12xc-repair/
Posted on Feb 04, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
There is an approximately 3" line of blue light
IS it like the picture is being cut off? You may need to check the connections to your buffer boards and main logic boards.
Thanks,
Michael
Apr 05, 2011 | Sanyo DP42746 42 in. Plasma Television
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Blue haze on my plasma screen
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Aug 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
Black vertical lines
ey there. have you solved this thing yet? you might want to check out this DIY plasma TV repair blog. there's a video on how to fix this.
Jan 23, 2008 | Samsung PPM42S3 42 in. Plasma Television
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Sanyo DP50747 50 in. Plasma TV Logo
116 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
